Original Urethane Bumpers
Old Jan 8, 2015 | 04:57 PM
Ike27's Avatar
Ike27
Default Original Urethane Bumpers
Just curious as to how many C3's still have their original urethane bumper covers.
My 76 has less than 23K on it, was garage kept. 2 years ago, the bumpers just started cracking..
Must be the rare exception to still have good condition originals?
Old Jan 8, 2015 | 05:13 PM
Cynical's Avatar
Cynical
As far as I know, my vette still does. No cracks in the front. Back end is wavy in areas, but not really noticeable. Back also has some slight cracks at the license plate recess corners, but not really noticeable.
Old Jan 8, 2015 | 05:31 PM
Ike27's Avatar
Ike27
That's sweet!
Mine being an early 76 with the recess for the logo.. I will never have a "correct" urethane..
Old Jan 8, 2015 | 05:37 PM
drkness01's Avatar
drkness01
That's sweet!
Same here.
My wife got me a "corvette" emblem for it .... its now on my desk at work. Should have been C O R V E T T E letters.
Old Jan 8, 2015 | 05:48 PM
Ike27's Avatar
Ike27
She tried!
I just put the old one as a surface mount.. after using the old bumper piece as a template..
Old Jan 8, 2015 | 08:27 PM
cb.bums's Avatar
cb.bums
She tried!
my 75 has good front and rear originals. usual front tip repairs, but minor.
Old Jan 8, 2015 | 08:47 PM
Ike27's Avatar
Ike27
I wonder if it has to do with the type of paint and its additives. Mine is bright blue metallic
Old Jan 8, 2015 | 08:54 PM
cb.bums's Avatar
cb.bums
originally, mine was white. sure they used lacquer till 1980. lacquer was lacquer.
Old Jan 8, 2015 | 09:24 PM
todd estal's Avatar
todd estal
my 75 with 20 k original miles on it garage keep car i had to replace both front and rear due to cracking the front lost a big chunk at freeway speeds when i got caught in a rain storm now have flex fit bumpers look great can not tell any different
Old Jan 8, 2015 | 09:28 PM
Ike27's Avatar
Ike27
I went with the urethane. Color match is about 90%. I just didn't want to blend into the rest of the original paint on the car. That blue metallic is a bear to get right.
Old Jan 8, 2015 | 09:46 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
My 73 still has the original front bumper has been garaged since 1984 but was outside with a cover the first 11 years. no cracks yet
Old Jan 8, 2015 | 09:57 PM
gbvette62's Avatar
gbvette62
The problem is with the urethane that GM used from 73-76. The urethane just seems to dry out, crack and fall apart. It wasn't limited to Corvettes either. The urethane nose pieces and bumpers used on the 73-75 Pontiac Grand Am's, and 74-75 Firebirds, also suffered the same fate.
It appears that GM changed the formula of the urethane, during the 76 model year. The early 76 rear bumper seemed to be about the last piece made with the original urethane. The urethane used from 76 on, holds up quite well.
I think it's the yellow urethane that didn't hold up, while the later "good" urethane is black.
Paint had nothing to do with the urethane cracking. People also have blamed it on the sun, too cold a climate an/or too hot a climate. None of this seems to be true, it really just seems to be something in the way the yellow urethane was made.
She tried!
Fiberglass bumpers are available with the indent for the small early 76 rear bumper. Both American Custom Industries and Tru-Flex (now owned by ACI), make an early 76 rear bumper. I think other companies may too.
Old Jan 9, 2015 | 08:22 AM
rene040269's Avatar
rene040269
My '80 has the original urethane bumpers and they look terrible.
One big wavy pile of crooked, spider-cracked, non-fitting floppy plastic. They ruin the beautiful curves of the car.
I am in the middle of a body-off resto and will throw these in the bin as soon as i start bodywork and my shipment of two new straight fiberglass bumpers has arrived.
You can pickup my originals for free if you care to travel to Europe....
Old Jan 9, 2015 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...how many C3's still have their original urethane bumper covers...
All of them which haven't been replaced. Of course, it's not an issue for 68-72 cars.
Old Jan 9, 2015 | 11:48 AM
stevelischynsky's Avatar
stevelischynsky
My 73 is still flexible and not cracked. But it's life has been in Canada with much colder weather and it was not in the summer sun either for most of it's life.
That tells me that it is the heat that is killing this bumper.
I bought a new spare a few yrs ago, just in case.
Steve L
73 coupe since new
Old Jan 9, 2015 | 12:10 PM
Brack c's Avatar
Brack c
As far as I can tell the ones on my 82 are original . Just had it painted & both were good
Old Jan 9, 2015 | 09:35 PM
Priya's Avatar
Priya
As far as I know the ones on my 79 are original. They're in good shape and still soft and flexible.
Old Jan 10, 2015 | 08:30 AM
Jim Shea's Avatar
Jim Shea
FYI,
What I call the "C-Clip Retainer" used on the T&T steering column is also made from urethane material. When you try to remove the 30 to 40 year old part, it typically breaks into many pieces. GM no longer services the part but it is available from many aftermarket sources.
This part serves two functions:
1. This is a critical safety part. It prevents the c-clip from migrating out of the slots in the yoke steering shaft. Without the c-clip in place, the steering wheel and upper steering shaft can be pulled competely out of the steering column itself.
2. It also is an insulator and prevents the big telescope spring from touching metal parts of the steering column and cause the horn(s) to blow continuously.
Here is the c-clip being installed.
Here is the retainer in place (over the c-clip).
Typically I recommend obtaining a new retainer before you even begin working on your T&T steering column.
Jim
To Original Urethane Bumpers
