Late C3 Taillight Idea
That is exactly the look I'm shooting for!! E-X-A-C-T-L-Y! Although in my State I do need back-up lights, so I'll have to choose between oldgto's LEDs or gwank's Eagle Eyes.
Thanks for the photo.
Chappie
http://www.corvettepassion.com/t459-...breuses-modifs
the rear bumper alone was a lot of work for a fiberglass newbie like I was then.
I started by molding the license plate recess twice
I used both parts to have a wider mold and used it to build a new wider license recess
and finally I cut a brand new fiberglass bumper and glassed the part
after cutting the backup light holes, I built some little brackets on the back (that's how the lights are mounted on early C4)
unfortunately, the lamps don't clear the real bumper and both the metal part and the honeycomb had to be cut (still need to reinforce the metal bumper).
the CORVETTE insert between the tail lamps was even harder.
a friend of mine cnc machined a plug for me
after many tries and vacuum assist, I've been able to get a clean part
for the exhaust, I started with a pair of dual tips from ebay and build it from there
They just tap into the original wires with scotch locks. Not too much damage to the wires. No relays required.
The lights have a 3/8ths In. threaded body and come with a nut. I did remove the white plastic square threaded "nut" from the filler panel. That leaves a 3/8ths in. square hole and the body of the light goes thru there with no damage to the car.
You will have to drill out the hole in the plate itself.
I have a build thread for the whole car on a french forum if you want (LOT of) pics.
QUOTE]
Thanks for sharing. Some great workmanship there.
It wasn't until I looked at the construction photos above that I noticed you did the mod I thought of- C4-style reverse lights on either side of the license plate. I went through your thread on the French website, you have some great details. If you don't mind, I"m also going to borrow your idea for the rear speakers and amp.
Lastly, I love the flat/satin sheen of the silver paint. It reminds me of the finish on F-22s and F-35s. Great stuff.
Chappie
We offer a new license frame for use when deleting the factory reverse lights. $36.95
This may simplify things for you guys
Tom@Zip
1-800-962-9632 ext 240
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Tom@Zip
I actually used one on a truck I had with a camper shell, more light for backing up always helps!
Tom@Zip
Chappie
