What did you do to your C3 today?
#3381
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
Motor mounts
Installed solid motor mounts and ARP bolts. Included for your viewing pleasure is Bubba’s handiwork, too long cross bolts, shimmed with a nut. Just do it right the first time
Cleaned and oiled K&N air filter, moved oil pressure switch to behind distributor, installed oil temp switch for soon to be installed oil temp gauge.
#3383
Since you have gone this far. Do not forget to check out the run out of your rotors. I believe it should be .005" or less. If it more than the .005" is one of the main reasons for constant bleeding the brakes. The rotors can be shined to get them to the .005" or less.
#3384
Hello Frank,
Rotors was one of the first things I changed to new. Did rework the calipers 2 times with new O-Rings. I hope its finished now
Cheers
Frank
Cheers
Frank
#3386
...left on a 3 hour cruise with about 51,886 miles, got back home with 52,003 miles, drained the oil & removed oil filter. Put on new PF-25 filter & 5qts of Brad Penn SAE 40W Racing Oil in the 'Ol '74. Next May 2019 will be 30 years of ownership. Bought her with 26,800 miles from the 2nd owner May of '89.
#3387
Had oil/filter and trans fluid and filter changed yesterday. Need to have them done professionally to keep the 2 year powertrain warranty in place on the white Rabbit(77 L-48). Runs very well and i hit the throttle at 60. Very nice jump ahead. All in all pretty happy with it. Winter project is carpet from willcox.
#3388
took out the cracked front windshield, cleaned the birdcage frame, suppringly no rust as the car spent the last 20 years in a garage with the old owner restoring it slowly. Installed a new windshield, got new tires. now it going on winter here in northern Virginia so no plates until spring. A complete years work done on it, to now strip the body again and send it off for paint.
#3390
#3393
2021 C2 of the Year Finalist - Unmodified
2017 C3 of Year Finalist
St. Jude Donor '13
Been cleaning up the engine bay over the last year and the valve covers drove me nuts trying unsuccessfully to clean off the tarnish so off they came. What a ball ache having to remove the A.I.R. pump and bracket all for 16th" of interference I had bought a pair of covers one year wrong from a Forum member so they went on and I had my originals polished.
The replacements have the twist off metal oil cap whereas the original 1971 is the plastic cover. I'll put the original back on sometime but I'm in no rush
Primoz (10-27-2018)
#3394
Ordered my new Powermaster high torque mini starter pn 9004-12, and received an email from SST that my chromoly 2.5" drive shaft was shipped.
#3395
Covers and engine bay looks fantastic!
#3396
Repaired the driver side regulator gears. Easy fix. Grinder and drilled out slots for more aft adjustment. Readjusted window to perfection. First time since I’ve had it that the window fits absolutely perfectly where it should.
Primoz (10-27-2018)
#3399
Power Brake Booster
Began the process of changing and replacing the power brake booster... having some trouble with the last nut to get the booster off if anyone has any suggestions....
#3400
You may also try a closed end wrench and tap it loose.
Think it through you'll get.
dmallen95 (10-29-2018)
