What did you do to your C3 today?
#1041
I have seen people brush it on is this the best method to coat the frame if you dont own an hvlp gun and spray booth.
#1043
Yesh hopefully only for a short time. My goal this week is to get the frame pressure washed and looked over then painted with more than likely por15.
This stuff works well down the inside:
http://www.eastwood.com/internal-fra...ay-nozzle.html
#1044
I've had good results with a die grinder / wire wheel, Duplicolor Rust Fix and Rustoleum.
#1045
#1046
Finished cleaning and putting the engine back together after new fuel line and strut brace install. Put new cushions in the drivers side. Seemed like everything on the cushion were narrow, had call for bubba. Now a good detailing and wait for the salt on roads to go away. And it's cruising time
#1047
I internally coated mine using eastwood. i used 4 cans and it worked great. I used green so that I can see any missed spots better. I recommend using cardboard or a plastic sheet under the frame because it WILL be messy.
MSGT-R (02-23-2016)
#1048
Nam Labrat
Received 4,179 Likes
I got the lowdown from Member Dub concerning saving my deck LID that the previous owner permanently bonded to the deck......
#1049
Received 3,139 Likes
#1050
how often do fuel sending units go bad in the 79/80 corvettes? i'm doing a full rebuild and mine works just fine. I'm wondering should i just throw a new one in.
today I ordered all new brake/fuel lines and electroless nickel plated my strut rod brace for the rear diff
#1051
If it ain't broke, don't fix it.
Wow, do you have a bore-scope for that frame?
#1053
If it ain't broke, take it apart and find out why not!
#1054
Last night i pressure washed the frame, trailing arms, center section, trans cross member, and leaf springs.
Hopefully round 2 can happen tonight when i get home.
Only found minor surface rust on a few places. Should come right off with some rust remover and be ready for paint in a couple days.
#1055
Received 3,220 Likes
I got my transmission mounted to my new removable x-over.
Since I'm running sidepipes, got rid of the mechanical parking brake by using an electric one, body is not off- so I didn't want to weld- I just used some 3" x 1-1/2" x 3/16" 36" in length steel rectangular for about $20.
Cut out the crossmemeber w/ a sawzall-
Slides in the drivers side-
Test fit
DSCN4446 by Richard Hayes, on Flickr
Drilled a few holes-modded the OEM bracket- painted it up- bolted it in- TKO 500
DSCN5973 by Richard Hayes, on Flickr
Also got the driveshaft in-
Test fit
#1056
I finished all the holes on my new cross member, now I have to get four nuts tack-welded to the outer ends. In the meantime, I put new rubber on my steering coupling.
#1057
Nam Labrat
I/Rookie asked the Members where the #3 body mount bolts were located
They were right....................
Can of worms.....................
