Wheel/tire recommendations
Old Jan 10, 2015 | 06:36 PM
cprinsc's Avatar
cprinsc
2nd Gear
Default Wheel/tire recommendations
I'm interested in opinions on mounting wider tires than what originally came on the '74 coupe that I am restoring, simply because I like the look, and I am really interested in staggering them. Any suggestions will be greatly appreciated...thanks!
Old Jan 10, 2015 | 08:15 PM
PeteL46's Avatar
PeteL46
Welcome to the forum! I would suggest seaching "wheel tire fitment". This will bring up page after page. The most important aspect (from a visual) is to maintain a 27"+- dia. For ex. a 225-60-15 (25 5/8" dia)up front will not fill the wheel well. Ask me how I know???
What type of restoration are you starting?
Regards,
Pete
Old Jan 11, 2015 | 10:42 AM
cprinsc's Avatar
cprinsc
2nd Gear
Regards,
Pete
Hi Pete...
Thanks for the insight. As for maintaining the 27" +/- overall diameter, I have read that it's extremely important to stay close to the factory 27.4" diameter since that is what the speedometer is calibrated for, agreed?
What I don't understand from your post is why a slightly smaller tire didn't fit.
As for my rebuild, not sure how to answer your question, since I'm brand new to this. I plan on driving it, so I am going to make a few modifications from '74 options, like paint (leaning towards dark metallic blue or black) and wheels/tires, to make it how I want it. My 12 y/o son is going to be involved, so my long-term plans are for him to receive it (once I am dead and buried).
The car I picked up has no interior at all (I mean only a steering column, loose wires, and a pile of trash)! It has the 454, which the previous owner said ran perfectly when he parked it 15 years ago. The body looks like it is in pretty good shape, with two small repairs to fiberglass I will have to make.
Old Jan 11, 2015 | 11:15 AM
Kid Vette's Avatar
Kid Vette
Here's a handy chart I put together. This shows tire availability at Tire Rack. It's a few months old but should still be close.
Old Jan 11, 2015 | 12:23 PM
PeteL46's Avatar
PeteL46
Hi Pete...
By maintaining the specified dia. (27 +-)you'll maint. the speedo calibration though I believe you can replace the gear for diff dia. size tires. Maintaining the propper dia tire is usually done to maint appearance. IMHO a smaller tire doesn't look appropriate for the size wheel wells these cars have though this is pretty much opinion based only. In 1993 I fell in love with Eagle Gator Backs which were one of the first directional tires.. I purchased a staggered setup with 225-60's in the front and 245-60's in the rear, never considering the ramifications of not filling the wheel well. Judge for yourself with photo of my car with the old setup. Another thing to consider is the inability to rotating front to rear. The only way to rotate a directional tire is to break it down from the rim and remount on the other side.
To answer your question, a slightly smaller tire will fit, just aesthetics.
Type of restoration: There are many types; full body off, body on, restomod, cosmetic. My guess is you're doing a cosmetic with a resto flare. Great!
You'll create great memories having your 12 yr old involved. Be patient! LOL. Above all teach him auto safety first. It took awhile to sink in... but my boys will never get under a car until jack stands are in place.
During repairs determine if the parts being replace are the originals. By rebuilding the originals you'll end up with a higher quality part than today's replacements.
Use this forum for any and all of your questions. A wealth of information!
Does yor car have the "born with" engine still in place?
Regards,
Pete
Old Jan 12, 2015 | 01:25 AM
Kid Vette's Avatar
Kid Vette
Originally Posted by B Stead
A Scratch race car uses a 275/35-19 front and rear. Search TR for "extreme performance" and there is a very good selection of tires.
The tire diameter is 26.6" and the sidewall height is 3.8". The wheel should be 19 x 9.5 0mm to -13mm. Well, 0mm moves the wheel to the inside while -13mm moves the wheel to the outside.
Forgestar has inexpensive custom wheels. The 19 x 9.5 F14 (Super Deep) is available in the range of offsets. The Howey website has an order form.
Or there's an RE-11 in 275/40-18. The tire diameter is 26.7" and the sidewall height is 4.3". The 18 x 9.5 Forgestar F14F (Step Lip) is available in the range of offsets.
Also:
255/40-18, 26" diameter, 4" sidewall height, 9" wide wheel
255/35-19, 26" diameter, 3.5" sidewall height, 9" wide wheel
265/40-18, 26.3" diameter, 4.2" sidewall height, 9.5" wide wheel
265/35-19, 26.3" diameter, 3.7" sidewall height, 9.5" wide wheel
Really, 275/35-19 on the front? Do they extend beyond the fender? Rub on the frame in turns?
Old Jan 12, 2015 | 05:34 AM
B Stead's Avatar
B Stead
It's frustrating. The 255/35-19 and 255/40-18 are an easier fit but they are short.
Run the 275/35-19 or 275/40-18 at -14mm offset and use a bolt-on fender flare. Lowering helps tuck the tops of the tires and only the tire tread must be under the fender line. They might claim the homologated ZL1 width which is really just the L88 (race part) fender flares. Basically, if they are using a C3 suspension geometry, the 275 tire, the 9.5" wide wheel, and offset between 0mm and -14mm then no-one is going to argue against a little fender flare.
Here is one suspension kit:
http://www.corvetteamerica.com/cf/di...ategoryid=x935
Old Jan 12, 2015 | 12:42 PM
qwank's Avatar
qwank
if you lower the car you can get away with a 26'' tire
Old Jan 12, 2015 | 01:25 PM
bullship's Avatar
bullship
Love the wheels can you tell us brand,size,backspace and source?
Old Jan 12, 2015 | 01:52 PM
qwank's Avatar
qwank
Rev Wheels, Classic 100. 17''x8'' -12mm offset. (4'' backspace)
Continental Extreme Contact DW 255/45ZR17 (26'' tire)
Old Jan 12, 2015 | 02:34 PM
outlawkinser's Avatar
outlawkinser
A little visual aid.
Rims: 15 x 8.5
Tires: Rear - 255/60/15
Front - 235/60/15
Mike
Old Jan 12, 2015 | 05:35 PM
Steve~74's Avatar
Steve~74
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
American Racing Torq Thrust IIs 16x8
Front 255/60/R16
Rear 255/50/R17
Old Jan 13, 2015 | 09:31 PM
bluegtp's Avatar
bluegtp
Staggered is an option for these c5 z06 wheels.
Old Jan 13, 2015 | 11:51 PM
ddawson's Avatar
ddawson
18 x 8 with 255/45-18's here
Old Jan 14, 2015 | 11:03 AM
qwank's Avatar
qwank
Your car looks great, Dawson
Old Jan 14, 2015 | 10:30 PM
3JsVette's Avatar
3JsVette
Go to the C3 Tech Forum and check out the wheel/tire sticky at the very top of the page. You can get several ideas there. See what you like.
To Wheel/tire recommendations
