Power brake conversion
Old Jan 11, 2015 | 06:50 PM
Tripower delight's Avatar
Tripower delight
Default Power brake conversion
what parts are needed to turn a manual brake car to a power brake car? Oh my car is a 69
Old Jan 12, 2015 | 02:28 AM
terrys6t8roadster's Avatar
terrys6t8roadster
That's quite a list you'll need. M/C manual 1"bore, P/B 1 1/8. Brake booster, not sure of pushrod length difference. Brake lines from master to Brass distribution valve will need to be changed. [P/B dist block mounted on frame very close to the steel line for LF flex hose] not sure where mounted with manuel. Vacuum hose, new fitting on intake, fitting into booster. Should be enough to get ya going. T
Old Jan 12, 2015 | 07:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the 69 assembly instruction manual (AIM) and flip over to the J-50 power brake section in Options. The AIM will show the factory installation and list the various parts you will need.
Old Jan 12, 2015 | 08:23 AM
bashcraft's Avatar
bashcraft
Or, just one part number.
http://www.parts123.com/corvettecent...50g&ukey=13682
Old Jan 12, 2015 | 01:34 PM
Richard454's Avatar
Richard454
Here's something else you should be aware of-
Look at the left set up (un-restored one)- it's for MANUAL brakes- notice the pushrod is using the TOP hole for more leverage.
Also notice different length levers for the brake light-since the power brakes use the lower hole for the pushrod.
The kit listed above by Bash -comes w/ the longer brake switch lever.
DSCN4771 by richardhayes454, on Flickr
DSCN4770 by richardhayes454, on Flickr
Old Jan 12, 2015 | 05:34 PM
Tripower delight
Thanks guys that was very informative,and its cheaper than I thought.
Old Jan 13, 2015 | 08:08 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Agree. Not terribly expensive nor all that hard. Just a fair bit of fidldly work. You'll have to drill a lower hole in the firewall and close off part of the old one. The bolts for the brake booster are a pain. The Clovis pin for the pushrod is a pain and the retainer is a royal pain. The striker plate for the brake switch is a pain. Are you noticing a theme?
To Power brake conversion
