1979 C3 suitable for Tall Drivers?
Old Jan 13, 2015 | 01:51 PM
Andreas Schmieg's Avatar
Andreas Schmieg
Default 1979 C3 suitable for Tall Drivers?
Hi,
I had a 1994 C4 before and did not really fit in it. My head pressed into the headliner. Is anyone 6'3" or taller comfortably driving a late model C3? I really don't want to drive a Smart car, just because the head room is great. And a C5, C6, or C7 is not in the budget.
Thanks for any help!
Andy
Old Jan 13, 2015 | 02:11 PM
widowmaker221's Avatar
widowmaker221
Originally Posted by Andreas Schmieg
Hi,
Andy
Pop the t-top out and you should be good to go!! Honestly these cars are a tight squeeze to get in and out of but part of the fun at the same time! I'm 5'11 and have the drivers seat all the way back just as a comparison.
Old Jan 13, 2015 | 02:33 PM
marc1973's Avatar
marc1973
Hi,
Andy
I was in the same situation as you, I Dailey drove a 1993 c4 for 2 years, I'm 6'7" most of my height is in my legs but I had to hunch over to not hit the room, from my search for my 1973, I sat in alot of c3s probably every year except 1968-1972, what I found is that literally every car is different it, a major factor is how deteriorated is the foam in the seats, my father owns a 1976 and I find I have significantly more room in my 73' than his 76' head room and sholder room, pretty much look for a car with really bad foam if you want more head room or another option is changing seats
Old Jan 13, 2015 | 10:59 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
If you get a C3 with glass T-Tops (or switch them out), you get about 1"
additional headroom over the fiberglass ones that have interior panels attached.
Old Jan 14, 2015 | 09:27 AM
cooper9811's Avatar
cooper9811
I/m 6'2" - I have a 79 with glass T-Tops, no real issues. Only ting is that at stoplights the header bar might obscure my view (the glass tops help with this though).
I have good seat foam and stock seats (new foam replacements) and so don't sit lower to the floor than I should. Not srue if that ehlps, but you can always look into a seat change. Should not be hard in these cars, as long as you find a seat that is the same width.
Old Jan 14, 2015 | 11:03 AM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by marc1973
. . . a major factor is how deteriorated is the foam in the seats . . .
That's why I'm afraid to redo my seat foam. I'm 6'4 220lbs in a '76.
Old Jan 14, 2015 | 12:27 PM
blk79nj's Avatar
blk79nj
I'm 6'2" also, but I don't have glass t-tops in my '79. I have no real issue's either.
Old Jan 14, 2015 | 01:21 PM
The13Bats's Avatar
The13Bats
C3 vs later years comes up a lot,
in this case I have to ask,
You can get into a comparable quality c3 for less than a c5-c6?
I am 6.2 never had an issue in my cars even the GT-40,
As I get older I do not tend to spring in and out as I once did,
Old Jan 15, 2015 | 12:41 PM
Shark Racer's Avatar
Shark Racer
I'm 6'2 and torso tall. Driving the C3 is pretty good. when I redid the seats (78 Pace Car), the new foam made things a bit uncomfortable on bumpy roads. I definitely hit my head from time to time.
Leg room is not a problem at all, nor is getting in and out. I can not drive the car with a helmet on and t-tops on - the few times I've raced it I've had to take the driver's side top off.
Old Jan 15, 2015 | 01:14 PM
74TTop's Avatar
74TTop
Default fit
My 2cents: 6'5 200lbs 74 coupe, manual, orginal interior, tilt & telescope column. I fit, no headrm issues. Leave lots of room to open door all the way, makes getting in and out easier. Door handle & headlite bright switch on floor give me problems which will be modded this spring.
74TTop
Old Jan 15, 2015 | 04:28 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
This brings up an all to often overlooked ergonomic factor whenever seating comes up for discussion, that there is no set torso/leg ratio shared by all persons of any particular overall height. Case in point: I'm only 5'10", but sit a couple of inches taller in the saddle than my 6'2" dad, so I'm "torso tall" myself (my dad is all legs). So, there's a bit more to any headroom (or legroom) issues than one's simple height. My $.02
Old Jan 16, 2015 | 05:04 PM
80Baby's Avatar
80Baby
Something to consider, as you get older... YOU SHRINK!!! I'm 1" shorter than I was when I owned my first '80. In another 30 years I'll probably need a booster seat to see over the dash.
Old Jan 16, 2015 | 06:07 PM
Wrencher's Avatar
Wrencher
Hi,
Andy
I'm 6'2" with a convertible and stock seats, so no problem. A former co-worker (6"4") had a coupe and he was miserable until he chucked the stock seat and bolted in a fixed racing shell with a custom insert he built up and then had upholstered. Voila!, he fit and his driving position was way better.
I do plan to occasionally race mine, and a hardtop (as well as a roll bar) are required, and on initial testing I will not fit with a helmet on. I'm hard against the top, so I'm looking at seat options.
Hans
To 1979 C3 suitable for Tall Drivers?
