this is my a/c
yeah i'll be laying out the same amount to build something somewhat factory, just can't make myself go aftermarket, seems opinion is split as to preference, factory vs aftermarket, just choosing to go with original type stuff
I am not poking I promise but any c3 AC system is based on very old antiquated tech,
If you have any c3 and the stock ac is working or close or you must keep it original then go stock, it will simply not cool as good as aftermarket but it will be stock and will cool as good as when it was new,
If your c3 has no ac or it's missing main parts & all messed up and you don't mind it not being stock you are so far ahead going aftermarket. ( even some purists go aftermarket )
Some of you know how cheap I am, I still would like a rack and pinion kit, overdrive tranny and AC but in florida AC is coming first on my 69,
I will do the install then take it to a good ac shop to check my work and vacuum it and fill her up...
Some of you know how cheap I am, I still would like a rack and pinion kit, overdrive tranny and AC but in florida AC is coming first on my 69.
So Bats makes a good point. The old stuff can be made to work, and work well for that matter. If originality is your goal, or your stock system can be made to work with little to no cost, then by all means that's the way you should go. But if you want a more modern, reliable system that can possibly freeze you out of these rolling ovens (and I've read several accounts here that VintageAir can do that if the car's got good insulation), then swapping for a new aftermarket system is the way to go.
* yes Bats, I know that when I start swapping out big parts my car turns into a 'project'.
And under the hood it will have a new compressor and new hoses to the A/C area. No big deal under hood as far as look difference unless you want bone stock look there.
You would spend much more to have a bone stock appearance under hood and have far inferior performance from it.
Everything will still work except the stock controls need to be adapted to work the sliding controls. Most people replace the stock control plate with one with 3 ***** for temp, fan speed and heat/ac. So still ok but not absolutely stock look like the earlier C3s
The last time I tried the stock A/C in my 1974 convertible (top up) was about two years ago. Ambient temp was ~90*F. I couldn't get below 60*F. I thought these systems should get down to 40*F. Am I wrong?
My dads case was always if you can get 20 degrees below outside temp in a car you are doing pretty well,
I always stuck those little good brand thermometers in the ac vents of our cars,
I have seen some darn cold readings at the vent but in the vehicle is another matter,
I would be thrilled with 60 in the cockpit of a c3 on a 90 day, I believe 40 would be asking too much but I wouldn't doubt some c3 ac vents would read 40 but not in the full cockpit.
did you play with it like highway speeds or spraying some water on he condenser?
Mom had an 80's tbird that here in Florida never really got cold I stuck a fan blowing into the condenser and man did it help big time.
It will be in 2015 when I add my ac I will play with seeing how cold I can get it at the vent and in the cockpit.
The 60*F reading was at the vents with a thermometer. I am not terribly worried about this. I don't think we saw a 90*F temp last summer and certainly my top was not up at any time. It was just one of those "let's see what happens" days to try it out. I thought a 30*F drop from ambient was not bad. But the GM Service Manual says it should be much colder. I'm not going to spend money on something I never use.
at the vents though is seldom what the interior temp really is,
I love convertbles hate direct sun on me ironic huh, AC is a must here in orlando and stuck in traffic on a hot day over 100 then with just a rag top my car will never be an igloo.
Like I said I would love 60 on a 90 day,
I would love to live in Florida especially on the coast. I would spend as much time as possible on the beach.
I got into the nightclub/music business early on so I stayed here, but that made me up nights more than days, I would go weeks sometimes months never put the top on the 66 daily driver,
Now dad passed this last sept and mom is in nursing home near the house so I have that,
We also spend a lot of time on the beaches, hit it in the late afternoon then stay until way after 12 midnight, we are dirt pirates, we metal detect...you would be surprised how dead Daytona, billed as the worlds most famous beach gets at night even during bike week which is fun....
