427 rip? bb fun build
The factory 454's were not internally balanced, the 427's were. If you have a 454 built up, you can have it internally balanced. Now it will rev like a 427. I would hope most built 454's are.
Breathing. Buy big block heads with rectangular intake ports. One rectangular intake port will have a cross sectional area that's equivalent to the entire exhaust of a Honda or Toyota economy car. GM says don't use the rectangular ports on a street car because the intake ports are too big...never had any trouble running rectangular ports on the street.
Sadly comparing apples to oranges doesn't help me,
Some Hondas and Toyotas with that little exhaust can and do spank hot c3's that's all they need so you see what I mean, but talking rectangle vs oval while I have not heard rectangle is too "big" for the street but rather for higher rpm, it seems they are reserved even by some bigger names in engine building for engines far more "race" that street, I fully believe yours works great on the street many factory cars came with rectangle ports but just like some cams are for low torque and some for high rpm hp oval ports are for one area and rectangle ports for another...
I do not know your driving style but if you are not doing higher rpms you don't "need" the rectangle ports and in some ways all other thing the same they might be hurting you.
Pig..The 454 shouldn't weight anymore than a 427. For Corvettes, the 1970 454's came out with cast iron manifolds...Arggh! The 69 427's came with aluminum manifolds. You can buy Edelbrock aluminum manifolds for your 454. or a 69 aluminum manifold will fit.
Pig Revisted...If you're building a big block for you Corvette, please buy aluminum heads. It really reduces the gross big block weight. Your Corvette will drive and handle so much noticeably nicer. A big block with aluminum heads and aluminum manifold weighs about the same as the all cast iron small block engine. Edelbrock makes aluminum water pumps for big blocks also.
I believe that aluminum heads on the bb make it weight the same as a iron sb but in my 69 when I went from a sb 383 to a 454 with iron heads I liked the "feel" of the handling better, now when my car comes back it will have a completely different suspension, the vb transverse front and rear, hopefully I can tune all that in to not loose any "ride" ...I am not auto crossing so I do not care about better handling.
Poor performing 454 truck engines. They came with the "peanut" cast iron heads. The intake ports were grossly restricted. The intake ports had a u-shaped cross section that some people likened to peanuts.
[COLOR="Purple"] They didn't "perform" poorly they were not performance engines they were truck engines...
COLOR]Building a 454 is yesterday's newspaper. Bore the cylinders out to get 496 cubic inches. Depending upon the block you may be able to go to 502 cubic inches.
No replacement for displacement is alive and well
Factoid: The rectangular port aluminum manifolds for a 67 breath a little better than the rectangular port aluminum manifolds for a 68/69, since the 67 hood allows the carb to set a little higher above the engine.
What is the power band of a 67 bb?
While the truck 454's didn't help the 454's rep what I believe really hurt it in performance circles was when GM killed it's factory HP after offering ones with nice HP,
4200 543 434
4300 542 443
4400 542 454
4500 538 461
4600 536 469
4700 536 479
4800 536 489
4900 527 492
5000 522 497
5100 518 503
5200 514 510
5300 507 512
5400 503 517
5500 495 518
5600 483 515
5700 474 515
5800 464 513
5900 442 496
6000 437 499
Here are some dyno numbers from a modernized stock 427 posted on the Chevelle Forum. The heads had some port work and a Mr Straub hydraulic roller cam. It looks like the build was designed to mirror the original specs as it peaked at 5500rpm. The build was probably done as a nice street cruiser. A lot of 454 builds use the RV cam for the same purpose, to build a nice street cruiser with a lot of torque.
