Sticky key locks
Old Feb 6, 2015 | 12:29 AM
TO_Vette's Avatar
TO_Vette
Default Sticky key locks
I've given up locking my doors since its so hard to turn the keys. I've replaced the key locks and put graphic on everything I can and its still really hard to turn. Any suggestions?
Old Feb 6, 2015 | 12:48 AM
cutlassdave's Avatar
cutlassdave
Cruising
Yes, we should all stop falling in love with 40/50 year old cars. The fun never ends. I have the same problem, but have not yet gotten around to dealing with it.
Old Feb 6, 2015 | 03:24 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Have you tried WD-40
Old Feb 6, 2015 | 03:59 AM
hunt4cleanair's Avatar
hunt4cleanair
Looks like you have an 80-82 and seems I recall one of those years power locks became a standard item which can complicate the fix.
The linkage can bind and especially as it ages, the gunk solidifies and needs to be cleaned from the linkage. If you have power locks, the actuator boots tear over time, moisture penetrates the plunger and it quits working requiring replacement.
Power door locks are electro-mechanical devices. Electrical power activates the plunger which moves the linkage...lock...unlock...lock...unlock. After years, the plunger gives out and failes to operate, binding up the linkage and making it difficult to turn the key. No amount of WD-40 or graphite can fix this. It requires full disassembly, cleaning, replacement. Afterward it will work like new...if this is the source of the binding.
Here's link to an article on the topic;
Tired of Key Twisting: RPO AU3 Repair
Old Feb 7, 2015 | 01:27 PM
TO_Vette's Avatar
TO_Vette
Is the electric actuator used only when using the door lock / unlock switch on the door panel is triggered? Or is the actuator also used when unlocking the car from outside via the key?
Old Feb 8, 2015 | 04:39 AM
hunt4cleanair
The key is a mechanical over ride of sorts but because the linkage is all connected it operates the electro-mechanical actuator in a mechanical mode. It is a dual function...the key operates it and electrical power works it. So when the linkage binds, neither will operate it.
Old Feb 8, 2015 | 11:48 AM
TO_Vette's Avatar
TO_Vette
So replacing my old warn out actuators and unbinding the linkage should do the trick. Sounds like the next weekend project.
Old Feb 8, 2015 | 03:37 PM
Cynical's Avatar
Cynical
As a heads up, sometime the elbow can bend/rust that operates the lock mechanism. It's easy to figure out once you take your door panel off. I'll attach some pictures.
The elbow (bent), just hammed mine straight and the locks work great now.
I'd start with some wd40 though
Goodluck!
Joshua
To Sticky key locks
