Wheel Adapter Info
Old Feb 13, 2015 | 01:48 AM
dpw21562's Avatar
dpw21562
Default Wheel Adapter Info
Going with different wider wheels. Present ones are 17 - 8" with 285's rear and 245's front. Now I have no clearance issues. New wheels will be 17 - 9" with 275's rear and 245's front. Math tells me I will need a 1" spacer on all four. Don't want to go through changing studs and want to know your views on using wheel adapters. Pros and cons please.
Old Feb 13, 2015 | 08:01 AM
Gordonm's Avatar
Gordonm
If you have the correct offset you do not need spacers. I am running 18x10 in the rear with 5.5 backspace and no adapters or spacers. Running a 275 40 18 with no rubbing
Old Feb 13, 2015 | 10:23 AM
929nitro's Avatar
929nitro
I will not use spacers beyond 1/4" max. Wheel adapters I have no problem with, prefer not to use them but I have a set of 1" just in case I need them when my work is finished. My alignment shop has no problems with adaptors but with spacers they said by law they cannot use more than 3/16".
To Wheel Adapter Info
