headlight gremlins on 73 L82!
Old Feb 15, 2015 | 01:41 PM
scottstmaxx's Avatar
scottstmaxx
Default headlight gremlins on 73 L82!
I've been trying to figure out this problem for some time now.
I recently replaced the high beam left headlight on my 73. Now the problem is that the low beam wont work, but when I push the high beams on all four work.
Any of the forum members have any suggestions or instructions!!
And before the questions start. I am that guy who tracked down his dads 73 that was all over the news and every Vette forum!!
Old Feb 15, 2015 | 03:45 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Have you tried another bulb? If not, swap the 2 lo beams and see if the problem moves with the bulb.
Old Feb 15, 2015 | 07:44 PM
GRipp 73's Avatar
GRipp 73
I believe the low beams have two bulbs inside of them as opposed to the high beams that only have one filament. So it is possible that the low beam filament is burned out, but the high's would still work. As mentioned, you can swap the two low beams and see if the problem follows the bulb, or if stays on the same side and is a wiring issue.
Good Luck.
To headlight gremlins on 73 L82!
