Light surface rust removal
Old Feb 15, 2015 | 04:26 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Light surface rust removal
I'm starting to assemble an engine that has been packed up for a while. Some of the parts have light surface rust. It's light enough that rubbing alcohol and paper towels will remove it but it takes a while and doesn't work well in rough places. What's the easiest way to clean these parts before WD40 and assembly?
Old Feb 15, 2015 | 11:37 PM
CA-Legal-Vette
I found a neat article on automobile rust removal:
http://www.hotrod.com/how-to/paint-b...removal-guide/
I'm going to try cider vinegar when I get home from work tomorrow.
Old Feb 16, 2015 | 08:15 AM
Mooser's Avatar
Mooser
Depending on the part, a light (red or grey depending on the brand) scotchbrite pad lubricated with WD40 will wipe light surface rust off and get into bumpy surfaces pretty well.
he cider vinegar is a very light acid so it works (also good for preparing ribs for the BBQ) but will attack machined/polished surfaces as well so be careful where you spray it.
M
Old Feb 16, 2015 | 10:58 AM
CA-Legal-Vette
That's a pretty good idea. I thought about Scotchbrite but there are so many to choose from that it's almost funny. I also didn't realize that the nylon pads have abrasives mixed in such as Aluminum oxide. I'll have to do a ittle research to pick the appropriate one but spraying WD-40 on the pad should help reduce any harm as well.
To Light surface rust removal
