Is there a trick on installing the retainer clip and spring for the sunvisors? It looks like you should be able to push the retainer down over the sunvisor stud but I can not get the clips to hold.
Push the sunvisor screw into the hole from below, from the top place the screw in and then sit the retainer clip on the spring. Get a size 8 or smaller socket that will fit inside the hole with the spring. Press down on it or attach a wrench to it and push it in the hole until the retainer clip pushes itself down on the sunvisor screw with the spring compressed.
Make sure your holding the sunvisor up against the hole from below while your pressing down.
Ok I was kinda doing that but what screw are you talking about? Also does the retainer cup face up or down?
When I say screw I mean the threaded rod on the end of the sun visor . The spring sits around it and the retainer lock washer compresses the spring down and locks itself into the threaded rod. You have to take the plastic silver cap off to see inside the support. My corvette is in the shop but I'll see if I can take pics of you havnt got it yet
Great thanks. I finally got it and what I did was use a quick grip clamp with a 8mm deep well socket. I just basically squeezed it into place and waw-law.
