Jacking up the front
Old Feb 25, 2015 | 08:00 PM
Tecdiverfl's Avatar
Tecdiverfl
Default Jacking up the front
Any safe way to jack with front up without messing up the bottom of the crossmember?
Old Feb 25, 2015 | 08:30 PM
Tom73's Avatar
Tom73
I jack mine on the frame right behind the wheel.
Old Feb 25, 2015 | 09:08 PM
Sayfoo's Avatar
Sayfoo
Put a 2x4 on your jack (placed front to back).
Old Feb 25, 2015 | 10:46 PM
68/70Vette's Avatar
68/70Vette
Use a hockey puck on the hydraulic jack pick up arm. It'll greatly reduce damage.
Old Feb 27, 2026 | 12:39 AM
RustyDuster's Avatar
RustyDuster
I got a floor jack differential adapter which goes in between the exhaust. I prefer this setup over anything going from the side.
Amazon Amazon
Old Feb 27, 2026 | 05:28 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I jack up under the doors. Jackstands just before the frame kicks up behind the front wheels. I walk it up. A bit on each side. Small floor jack just behind the jack stand. Going back and forth side to side until I'm happy with the height.
I never, never jack on the front crossmember. It's just to thin. I don't care what people pad the jack with. I don't jack there. I take my time one side at a time.
Old Feb 27, 2026 | 09:56 AM
OldCarBum's Avatar
OldCarBum
The factory recommended jack points are on the side frame rails just where 4Vettes stated above.
I used these points and never had any issues.
I bought a second floor jack which made the task faster and easier, but if you only have one jack, do as 4 Vettes said and go a little at a time from side to side.
Same thing to jack the rear.
Old Feb 27, 2026 | 01:49 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
As the members said..THE RIGHT WAY IS THE BEST WAY. Put a anti-roll block behind each rear wheel.
When I'm in a hurry I cheat and place a 6" X 6" X 2" thick board on the pedestal of a 2 ton floor jack centered slightly to the passenger side of the crossmember for balance.
Once I lift the front of the car enough I place the jack stans in their correct postions and slowly lower the car onto the stands.
Old Feb 27, 2026 | 04:29 PM
71 Vert LS1's Avatar
71 Vert LS1
I read somewhere that someone took piece of 1"x6"? and added tapered pieces of wood to both sides of the 1"x6" to match the contour of the cross member. That way you could jack right on the cross member with one jack.
To Jacking up the front
