Adjustable Struts.
Old Feb 27, 2015 | 10:44 PM
KLUTZ's Avatar
KLUTZ
Default Adjustable Struts.
I'm thinking of ordering the adjustable struts for my '73 project instead of R&R ing my existing struts and was wondering if it is still necessary to order the strut rod camber adjusting bolt or do the struts come with a different type bolt?
Old Feb 28, 2015 | 07:04 AM
Gordonm's Avatar
Gordonm
The adjustable rods are threaded tubes. This is how you get the adjustment. No need for the camber bolts.
Old Feb 28, 2015 | 08:56 AM
KLUTZ's Avatar
KLUTZ
Thanks, but do the adjustable struts come with a bolt to replace the camber bolts or is that a separate or item that needs to be ordered to install them?
Old Feb 28, 2015 | 09:11 AM
Gordonm's Avatar
Gordonm
It comes with everything you need. New bolts for the camber side of the rods.
Old Feb 28, 2015 | 09:17 AM
Mooser's Avatar
Mooser
Mine came with everything. I did have to file / fit the square "washers" to the lower carrier as they were slightly too wide
M
Old Feb 28, 2015 | 09:22 AM
KLUTZ's Avatar
KLUTZ
Great.. Thanks.
To Adjustable Struts.
