Hi all. Looking for some opinions. Changed out the engine, 350 in my 74. So im putting stuff back in. Its a 4spd and converted the factory air to one of nostalgic airs systems. The radiator is in good shape and it cooled fine before. That was without the ac working. Also when I removed it found that it was running without a t- stat. So my question is do I change over to a new aluminum radiator or put the old one back in? Trying to keep costs down, but that went out the window when I pulled the engine lol. Don't want overheating problems down the road.
Thanks Brent
Doing the same thing. I don't know the age of my existing radiator and it's so much easier to remove with the engine out.
I'm a big block though. I bought a Champion and it wont fit. Doesn't fit into the hold downs at all. Ordered a Dewitts from Summit which everyone says is a drop in.
Well, the radiator is just a surface area to cool down the coolant. IMO, especially if you're trying to cut on cost, if it is not leaking, just stick with it. Not running a t-stat increases use on the water channels for nothing and makes the engine run cool for nothing. Adding AC won't change anything regarding temps since it doesn't use the same circuit (unlike heating)
take the radiator in for a pressure test and checkup,
they can tell you if it will function properly, or if it needs rodded /cleaning inside.
if they say good to go, run it.
it was originally designed to cool a small block, if in good shape I prefer the original.
highly suggest adding the T-Stat back in to the car.
On the other hand......my 350 SBC was staying cool with a 180* thermostat.....I installed vintage air and had overheating problems in traffic to the point that I had to turn the a/c off in traffic jams in July/August......NOT GOOD!
I added a pusher electric fan which helped some, but still overheating and I wasn't going to fry a good engine.
I bought/installed a late-model GM aluminum radiator the correct size and the SBC is as cool as can be in 99* traffic jams.
If my project were completely original I would have bought a direct replacement radiator....but it's a resto-mod because of previous owners butchering.
Thanks Brent
I just changed mine out this weekend, not as bad of a job as I thought it would be. My opinion is to change it out for piece of mind.I installed a Champion 3 core and it fit great by the way!
Thanks for all the replies. Next question, if I do replace it are the $200 dollar ebay type radiators any good or do I need to spend $500 plus for one.
Thanks again Brent
I was in the same boat also. I upgraded my engine to a GMZZ5 and added a Vintage air . I never had overheating issues prior to the disassembly of my 1974 . I wasn't sure if I wanted to use the original radiator again after a core cleaning and inspection. after thinking about it for a while I decided to pull the trigger.although I'm still in the middle of the resto/mod I'm sure I will be glad I wont be pulling the radiator out of that tight spot once I'm done..!
If the original was not a problem and you're trying to keep cost down do this
On the other hand if that turns out to not be the case as the others have said Dewitt's is the way to go. Yes you can spend less and it may or may not fit without issues but you get what you pay for. IMCO there is nothing more important than the cooling system (maybe the oiling system) so that's not the place to gamble.
Consider that air conditioning was an option in '74, I would check the AIM under C60 and see what we're the differences for the small block cars with AC vs. non-AC cars.
If the radiator is in good condition (straight fins, clean, passes pressure test) I would strongly consider reusing it. Make the necessary adjustments for C60 (7-blade fan perhaps?).
If, in the future, you are not satisfied with your cooling capacity, evaluate the entire system and determine if the radiator really is the problem. You'll find replacing the radiator a fairly straight forward project.
