identify c3 differential
Old Mar 23, 2015 | 09:41 PM
gator79's Avatar
gator79
Default identify c3 differential
I discovered my 64 has a C3 diff in it, the rear u joint for the pinion is 3.5 inches and the C2's are 3.25 inches. realized this chasing a vibration with a new drive shaft. By spinning the drive shaft and counting tire rotation it is somewhere around 3.30 to 3.50
Old Mar 23, 2015 | 10:48 PM
Tom73's Avatar
Tom73
Is there a question in there somewhere?
Old Mar 23, 2015 | 11:16 PM
Iceaxe's Avatar
Iceaxe
Spin the wheel 10 revolutions and count the drive shaft revolutions than divide by 10 if you really want to know what gears you have in the rear end.
Old Mar 23, 2015 | 11:23 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I'll ask a question for the O.P.: Will a C3 Pinion Flange fit on a C2 differential (If it will fit, he still may have a C2 differential)
Old Mar 24, 2015 | 06:58 AM
bashcraft's Avatar
bashcraft
My '69 has a C2 diff in it. The u-joints were the same.
Old Mar 24, 2015 | 07:39 AM
gator79's Avatar
gator79
on my 64 the front bolts that mount the differential support should be threaded into the housing with the back bolt going thru the differential with a nut securing it as per the AIM. Mine has 2 thru bolts like my 71 has and my car was originally a power glide car that should have a 3.08 ratio, so I know it is not correct for my 64. Just trying to determine the year of the differential I have, not a big deal I bought a conversion u joint and all works fine. You never know what has been done to these cars over the last 50 years. With the Ls1/T56, Steeroids, disc brake and vintage air conversion the next owner should be totally confused . I am keeping a list of parts and putting it in the glove box
Old Mar 24, 2015 | 08:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Differentials are coded. Get the codes off of yours and look up the numbers.
Old Mar 24, 2015 | 12:37 PM
joewill's Avatar
joewill
yes there is a casting date on your differential pumpkin.
To identify c3 differential
