82 Corvette Timing problems
Old Apr 3, 2015 | 10:38 PM
dcdecs's Avatar
dcdecs
Default 82 Corvette Timing problems
I purchased a 82 Corvette that had been stood for a while so changed the plugs, cap, rotor, oil filter, throttle position sensor everything that goes along with a full service.
The car starts and runs but the timing is out. Currently the car is firing on 6 degrees before TDC on cylinder 8 instead of 1. I disconnected the ECM lead to the distributor and found TDC on number 1 cylinder set the cap and lead to fire on cylinder 1 and tried to start the car.
The car wont start or even try and fire if I set the timing up on cylinder 1, if I set the car to fire on cylinder 8 first the car starts and runs.
Any ideas I am completely stumped as what to do next? I have set the timing up on many cars and never had this problem.
Old Apr 4, 2015 | 09:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
When you set #1, did you have #1 TDC on the compression stroke or the exhaust stroke?
Old Apr 4, 2015 | 09:49 AM
terry82's Avatar
terry82
also I would check balancer wheel to see if it has moved .
Old Apr 4, 2015 | 09:56 AM
dcdecs's Avatar
dcdecs
yes i set it on number 1 compression. if i clip my light on 5 or 8 the timing is right on 6 degrees i have never had this before its strange
Old Apr 16, 2015 | 06:31 PM
dcdecs's Avatar
dcdecs
Just to update this thread I found the problem, the harmonic balancer had slipped and was causing all the timing problems. Replaced it and timing is now good.
To 82 Corvette Timing problems
