electrical problem in 1982 corvette
Old Apr 11, 2015 | 11:54 AM
Robert P Brueckmann's Avatar
Robert P Brueckmann
2nd Gear
Default electrical problem in 1982 corvette
my question is i have changed everything from fuel pump to distributor and car still wont start. pulled car out of garage to try to find why car battery kept going dead jumped battery tested all fuses and realized fuel pump wasnt working Started there , changed fuel pump , ecu, prom ,oil pump pressure sensor. there is power up to injectors .Checked with droid. Found distributor was toast changed that , car still wont start, any thoughts thanks BOB
Old Apr 12, 2015 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "won't start". Does the engine turn over?
