68' Help with identifying this dash wire
Old Apr 11, 2015 | 10:24 PM
tomdoc's Avatar
tomdoc
Default 68' Help with identifying this dash wire
Forgive me for double posting this question in both the General and Tech/Performance forums but I am desperate for help with identifying this dash wire. I posted this question a few weeks ago. This time I am attaching a pic with the post. This 12 gauge brown wire with a female black connector is coming from the igition bundle of the wiring harness just behind the ignition switch (68 has the ignition switch in the dash) and gauge cluster. Some members thought it may be wired to a radio noise suppressor but I still don't know for sure. I do have wiring diagrams but I still am confussed to where it goes. I am having problems with my ammeter, seat belt warning light, low fuel and door ajar indicators working and my fuel gauge working correctly on the gauge cluster. Maybe this wire has something to do with energizing the gauge cluster?? I'm giving this issue one more try on my own and with the help of members on the forum before I throw my hands up in the air and bring the car to a shop..... Thanks guys..... I am so frustrated with this issue..... Tom.
Old Apr 11, 2015 | 10:58 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
My wiring diagram shows that it plugs onto the back of the ignition switch on the terminal that is next to/perpendicular to the pink wire terminal and sends voltage to the firewall then to the brown-white wire that goes to #4 regulator terminal. It also branches off and goes to a couple other areas that I'm not sure about......
but it does seem that it is supposed to receive power from the ignition switch.
If you have an aftermarket ignition switch there is no telling if there is a terminal to plug it onto or not.
Old Apr 12, 2015 | 10:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Factory radio? It could be for the RFI capacitor. UPC U69 Sheet A3 in the AIM.
Old Apr 12, 2015 | 10:23 AM
doorgunner's Avatar
doorgunner
Easy Mike......I found this pic....but I'm not sure if the brown wire in the pic is the same as in the diagram.......(I added type over the print)
Old Apr 12, 2015 | 10:59 AM
speedreed8's Avatar
speedreed8
i looked over some sch. i have for a 68, shows brown wire plugging into rear of ign. switch. goes to #4 term. on alterntor. also branches off to another highlighted connection box but is not labeled, but i think its the fuse box. just some fyi.
Old Apr 12, 2015 | 11:50 AM
1Fordman's Avatar
1Fordman
There should be a brown 12 ga. wire in the molded connector that plugs onto the ignition switch. That wire supplies power to the fuse block on the ACC side. The loose brown 12 ga. wire in the photo is spliced off of the brown wire in the harness and plugs into a radio noise capacitor. The capacitor is to dampen any electrical pops generated on the ACC side components.
When you turn on the ignition switch that wire goes hot.
In my 68 the capacitor it plugs into is mounted on the backside of the tach.
In the wiring schematic and an oh so ez laminated colored wiring diagram that wire is labeled radio noise conn.
Old Apr 12, 2015 | 11:51 AM
tomdoc's Avatar
tomdoc
Thanks Guys. With regards to the ignition switch..... I'm pretty sure all the poles to the switch are wired correctly. What I mean by that is.... There are 7 poles in the back of the switch of which only 6 are used. The only pole that is not used is the pole labeled "Grnd" ground. I understand from previous posts that ignition switches were used for several different models of GM cars. NOW.... The pics I have posted are of a new ignition switch I bought and installed but is not correct. If you notice the plastic retaining bars in the pics of the harness plug are in the wrong position. I have since then changed the ignition switch back to the switch that was in the car. I just swapped out the key cylinder and acheived what needed to be done because the key cylinder was worn and rotated with out the key. The female connector on the wire that we are talking about won't fit in the harness plug even if IS to be used on the ignition switch ???? Again..... Still baffled ?????? Thanks, Tom.
Old Apr 12, 2015 | 11:58 AM
tomdoc's Avatar
tomdoc
Doorgunner.... I'm wondering if you're onto something! Maybe the ignition switch is incorrect...... BUT, I understand that there are seven poles on the igition switch and only 6 are used. The pole labeled "GRND" ground I understand is not used. That is how this switch is wired though.....
Old Apr 12, 2015 | 12:12 PM
tomdoc's Avatar
tomdoc
Thanks Fordman. I hope your are correct!! Maybe somewhere along the 47 years of this cars life this wire was just left off?? Does the noise reduction capacitor you talk about look the same as the capcitor that is also mounted on the back of the gauge cluster just above the clock?? Thanks, Tom.
Old Apr 12, 2015 | 12:49 PM
doorgunner's Avatar
doorgunner
It looks like Easy Mike and Fordman found the answer.
I have an aftermarket switch also.
As for your big problem with the cluster....I connected an extra ground wire from the metal cluster bezel to the case of the radio/I did the same thing with the wiper dash switch to eliminate the possibility of faulty grounds.
My fuse block had internal corrosion.....when I turned the ign to ON and tapped on the block the gauges would work for a day or two.
My fuel gauge had a faulty ground at the frame near the gas tank.
My door ajar switches weren't closing completely causing the light to stay on.
My ammeter had a bad connection at the voltage regulator.
I think Willcox has a fuel gauge test instructions to determine if the gauge or sending unit is defective.
Old Apr 12, 2015 | 10:05 PM
1Fordman's Avatar
1Fordman
The capacitor has a molded connector (male) that mates to the connector on the wire you have.
The capacitor looks the same as the one near the clock. if I remember correctly it has a different end and is for the clock when it rewinds and the contact points make and break contact so you don't get the popping in the radio.
Old Apr 12, 2015 | 10:08 PM
1Fordman's Avatar
1Fordman
There are 2 ignition switches from the era that look the same but the molded connector has the 3 tangs in different places. One is Corvette specific and the other for various passenger cars and trucks.
The ground connection is used I believe for the key buzzer warning on the 68's.
To 68' Help with identifying this dash wire
