Control Arm Crossbar
Old Apr 15, 2015 | 01:40 PM
cgarcer's Avatar
cgarcer
Default Control Arm Crossbar
I am rebuilding the front control arms. Here is a pic of one of the crossbars. They all have these grooves that run around the end where the bushing goes. I haven't seen a new one to know. Are these just machine marks or is this wear from grit getting inside of the bushing that warrants replacement?
Old Apr 15, 2015 | 03:38 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Hum, not "original" by any means.
Pretty uniform marks to be caused by "random" grit.
Looks intentional but can't think why someone would do that - perhaps the previous owner installed poly bushings?
Good news is - the original rubber bushings don't move on the bar when properly installed (they're clamped in place by the end bolt and the bushing teeth bite into the shoulder). So, unless you get alot of slop between the bushing ID and crossbar OD you should be good to go.
Old Apr 15, 2015 | 07:12 PM
Mooser's Avatar
Mooser
Factory are pretty rough machined but I've never seen any that coarse.
There's not enough rotation to have any "grit" create lines all around.
I knurl mine to improve the fit but that gives diamond or horizontal marks.
Check the measurement, should be somewhere handy to
Upper shafts .670-.676
Lower shafts .738-.742
Old Apr 15, 2015 | 07:47 PM
twinpack's Avatar
twinpack
I am doing mine now also. Mine do not have any grooves or marks.
Old Apr 15, 2015 | 09:14 PM
cobrachuck's Avatar
cobrachuck
C
I just did my 75 they did not look like that, does not look oe.
Chuck
Old Apr 16, 2015 | 10:19 AM
BP 77's Avatar
BP 77
The final machining was very coarse. Rust is about 8 times larger than steel, so the grooves are accentuated. Mine looked like that on my 77. A little bit of time on a wire wheel made a world of difference.
To Control Arm Crossbar
