What to use to remove fine scratches
I HAVE A 78 PACE CAr that I just purchased. The paint is very good but the prior owner used the wrong towels to clean it. What can I use to remove these fine scratches and some swirling marks?
Mostly fine scratches on the pain. Its Black and silver exterior.
I was going to first clay it but I know that clay will not remove them. Any suggestions?
I have had good success with meguiras ultimate compound. everyone has there own favorite.
http://www.autogeek.net/meguiars-ultimate-compound.html
Nam Labrat
Received 4,178 Likes
Congrats on the new car.....post some pics!
Received 3,139 Likes
M
PS start with a hand compound, you may be surprised what comes out without getting out the polishers.
Just tried the Meguairs Ultimate Compound and works great. It requires some elbow grease but as long as it works. Then I will put a polish over it once its all done. Thank you
You want to start with the least abrasive product you can. Do a test spot after claying with just meguiars ult. polish first. Use a da if you have one. But, meguiars ult. compound (if needed), Polish and wax will light that black paint up. And only use mf towels.
Thank you. I use only MF towels from auto geek. The best ones for my Vette. Any suggestions for the leather Silver interior? Not dirty just want to brighten it up some. Thanks
I had the same problem with my 78 Pace Car, especially on the black flat surfaces. I was successful in getting a mirror finish by using a clay bar first and then used meguiars with a 7 inch random orbital polisher.
Thanks any pictures of your 78
The clay bar process will not remove scratches, only surface contamination. You could try a small section (about 2ft x 2ft) and slide your CLEAN, DRY fingers across the original surface and the clay bared surface and see if you can tell any difference. If there is not any noted difference, I would spend the rest of my time working on the scratches and spider web. You can find a good random orbital palm polisher at Advance Auto for about $20. Just let the weight of the polisher do the work keeping it in motion. Don't get in a hurry, let the polisher do the work. Black will show the slightest scratches so get a "California type duster" to remove the dust when showing the car. I spent 3 days polishing my hood and rear deck and spoiler. They really came out nice.
Just last week, I used Meguires cleaner, followed by Meguires polish, followed by Meguires carnuba wax. Great results. Wish there was a sealer to finish it off.
For general upkeep and minor swirl marks etc I prefer them over the other stuff I've used (you name it, I've probably tried it at some point)
BUT
For heavier marks I'll go right back to Meguires or 3M (fresh paint safe)
You'll like the buttery way but if your comparing to zaino you'll need to dig deep and step up to one of their paste waxes (americana or patriot) to get the longevity.
I highly recommend their VRT for tires, switched the other year from 303 with no regrets and I really liked 303
M
Basic process should go something along these lines but people have their own methods and what works for you - works for you.
heavy rinse
clean the wheels (do not dress them, just clean)
Door jambs
2 bucket wash
check and clay if required (thin plastic bag on your hand and gently go across the car, if you feel / hear anything you should clay) Make sure you use a proper lube when claying the car
paint correct (if required, if you clayed the car it should at least need a quick polish, maybe even just by hand) you may or may not wash clay residue off, honestly doesn't matter if your buffing anything)
Dress wheels (if using and applicator or sprays)
exterior glass (if required, I usually do it with the wash)
Wax/seal whatever your preference
Dress wheels (if using applicator)
If it's just a touch up for the weekend
clean wheels
not real dust (ie under a cover for the week) detail spray or waterless/rinseless wash if it needs a little cleaning
dress the wheels
All the best
M
Please consider not using a California duster, especially on black.
Or something like that, insert beer as required
And that is a beautiful SA/PC
M
M
