Luggage Rack Hardware
so i thought i'd replace the rubber washers under the luggage rack, whilst i can get to the stubborn well nuts that keep spinning.
i have found a corvette fastener site that sells them, and even lists the OD size, 1-7/16".
we have rubber punchouts at work the correct diameter.
but what size hole is in the center?
well nuts are 1'4"-20 x (i think) about 1" long.
yes, you can buy kits over there, but it would cost me more in postage to import than it would to source local bits
The important thing is to match the size and thickness of the head on the well nuts you can get
HIH
M
have seen some with large holes, and some with smaller holes, like only the body of the well nut passes thru.
just trying to get the parts ready so i dont have too much down time when i start.
M
