Antenna Relay
Old Apr 29, 2015 | 06:22 PM
biackbenz's Avatar
biackbenz
Default Antenna Relay
I needed to post these in a PM but couldn't so I am using this. But you might be interested in seeing this. This is the antenna relay located under the console arm rest of my '78. It would appear that these parts go a little warm! The armature of the motor was toasted as well. My guess is the antenna got jammed and the PO just let it run. But, I should have it fixed shortly.
