Parasite 1981 c3 vette
Old May 3, 2015 | 11:13 PM
Dmossy96's Avatar
Dmossy96
4th Gear
Default Parasite 1981 c3 vette
Help my battery with everything off and doors closed I connected a tester from the - neg cable and the -neg post on the battery the light comes on the tester and when I have replaced that with a volts ohm meter 3.98 dc amps was being pulled. I started pulling fuses and found 2 fuses 20 amp for clsy and then the 15 amp anti theft fuse. This completely stopped the bleed on the battery. I checked that everything was turned off along with pulling the curtisy unit behind the glove box. I'm not sure if the anti theft switches in the doors might be shorted. I did notice that when the car is running with the door open the curtisy lights had a flutter even if I gave it more gas the lights still seemed to still not stay steady. I also had my auto mechanic do some gauge work done and got it fixed but I don't know or remember it the glove box had a light in it because there is a button but no light and is there a curtisy light below drivers side under dash
Old May 4, 2015 | 08:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The glove box has a light. Check the bulb.
