Rear Drops when Put in Drive
Old May 4, 2015 | 08:05 PM
jokerman2k's Avatar
jokerman2k
Default Rear Drops when Put in Drive
Just got this 79 Vette after having an 84. It's an automatic. When I put it in Drive the rear end drops. Kind of cool feels like it's about to jump but I know it's not normal to do that.
Shocks, tranny mount, not sure. Any ideas? Anyone had this happen before where the back end drops when you put it in drive?
Thanks,
Old May 4, 2015 | 08:11 PM
bobbarry's Avatar
bobbarry
My '71 does the same. Not a lot, but noticeable.
Old May 4, 2015 | 08:23 PM
'75's Avatar
'75
That's normal, every C3 I've been in does it.
Old May 4, 2015 | 08:47 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
My '68 project would drop about 1&1/2" when put in Drive. I replaced the longest leaf on the springpack and installed new shocks.......
now it only drops about 1/2" when I put it in Drive....when I romp on it, it drops half as much as it previously did.....the front end raises about 2 inches.
It now has the same feel as my '69 Camaro which had traction bars.
Old May 4, 2015 | 10:10 PM
Jartanyon's Avatar
Jartanyon
that's normal, every c3 i've been in does it.
+ 1.
Old May 4, 2015 | 10:31 PM
Tom73's Avatar
Tom73
Just a fact of life with IRS. Driveshaft pulls the differential down as the pinion gear tries to climb the ring gear.
Old May 4, 2015 | 11:22 PM
gjohnson's Avatar
gjohnson
Normal
Old May 4, 2015 | 11:42 PM
qwank's Avatar
qwank
If the front snubber bushing is worn out the drop might be excessive
Old May 5, 2015 | 06:34 AM
Bad Bird's Avatar
Bad Bird
Yeah, just an IRS thing. Every car I've owned that had IRS did this. I think that it's pretty cool actually.
Old May 5, 2015 | 07:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Posi-traction.
Old May 5, 2015 | 01:40 PM
PRNDL's Avatar
PRNDL
"squat"
https://www.corvetteforum.com/forums...rchid=47059312
Old May 5, 2015 | 02:11 PM
sstopczy's Avatar
sstopczy
I agree. Check the condition of this bushing, mine was shot. Squat greatly improved with this. http://www.parts123.com/corvettecent...50g&ukey=11791
Old May 6, 2015 | 10:51 AM
jokerman2k's Avatar
jokerman2k
Looks like if it's normal I'm good with it. Like i said feels cool like it's getting ready to jump. Now that i know it's normal (to a point).
Old May 7, 2015 | 12:41 PM
widowmaker221's Avatar
widowmaker221
Thanks,
This same thing freaked me out last year when I first got my car too.I hadn't even thought about it this Spring until this thread. I also believe it is due to the IRS so it's normal.
Old May 7, 2015 | 03:39 PM
Capkunu's Avatar
Capkunu
If you don't find yourself sitting on the pavement, all is well.
Old May 7, 2015 | 08:45 PM
kdf1986's Avatar
kdf1986
Mine does the same thing. Something I look forward to because it has been a feeling I get from owning my first Vette back in 1981, and every automatic since then.
kdf
Old May 8, 2015 | 06:35 AM
bkvette3's Avatar
bkvette3
Love the feeling. Ready to pounce.
To Rear Drops when Put in Drive
Old May 8, 2015 | 08:58 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Agree especially if you start hearing a clunk when putting them in gear or letting out the clutch. most automatically think rear end issues but more times than not, it's the bushing wearing/wore out.
Terry
Old May 8, 2015 | 09:39 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
You should see the two divots in the grass, when putting an automatic L88 in drive!
With two feet on the brake!
Old May 8, 2015 | 07:06 PM
bkvette3's Avatar
bkvette3
Sweeeeet!!!
