Wire plug help
Old May 5, 2015 | 08:21 AM
Mikesfreetime's Avatar
Mikesfreetime
Default Wire plug help
Does anyone recognize where this goes? It has a fusible link, a couple grounds and at the other end goes into a purple wire.
Old May 5, 2015 | 08:40 AM
jnb5101's Avatar
jnb5101
Purple is usually the starter safety switch. Probably an after market kill switch wired in with the yellow wire replacing the other purple wire originally connected there.
Old May 5, 2015 | 10:01 AM
Mikesfreetime
Interesting thought, I will email the original owner and ask
Old May 5, 2015 | 11:55 AM
Mikesfreetime
Well I spoke to the original owner he doesn't recognize it and says he didn't add anything.
Old May 5, 2015 | 11:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
To my recollection, GM did not use in line fuses on C3s. Have you checked the AIM to see whether it shows it?
Old May 5, 2015 | 12:12 PM
Mikesfreetime
Yes, from what I can see its not there but I admit Im not a great manual guy, Its not laid out well to me but Im a techie not a car guy so. But I questioned the fusible link myself.
To Wire plug help
