1976 door panel help
Old May 5, 2015 | 08:06 PM
aaronarbogast's Avatar
aaronarbogast
2nd Gear
Default 1976 door panel help
Needing help with the door panel and installing a new door handle. I can't open the door only from the other side of the car internally
Old May 6, 2015 | 12:00 AM
GaToy's Avatar
GaToy
Ok. I have read that three times and I still don't understand what your asking. I get that you are iinstalling a door handle. Is it the inside or outside one? If you make your questions clearer there are a lot of knowledgeable folks on here.
Old May 6, 2015 | 03:34 AM
drkness01's Avatar
drkness01
Drivers side or passenger side?
I currently have my driver side panel off and can take pics of everything if you need them. Im planning on reinstalling my lock rods this weekend.
Old May 6, 2015 | 09:01 PM
aaronarbogast
2nd Gear
Ok sorry for not being clear. I have the driver side interior door panel off. The exterior door handle has a spring assembly and I believe the spring is broken. When opening the door from the outside of the car nothing happens ( once you push or clamp down on the exterior door handle) sooo i was thinking about fixing the spring or just buying a whole new assembly.... I have not priced anything out or looked around I was hoping to just fix it with a new spring...IDK
thanks
Old May 6, 2015 | 10:24 PM
gjohnson's Avatar
gjohnson
I would just by a new handle
Old May 6, 2015 | 11:26 PM
tpfarm's Avatar
tpfarm
I agree with gjohnson, just did it on my '73 with a new handle from Trim Parts, couldn't be happier with the part.
To 1976 door panel help
