I think the 70 LT1 PS oil pan was the same the L46 oil pan and later LT1 oil pans. That looks
like the correct oil pan. It should have 3 ribs on the LH side, correct.
Thanks for replying. Yes it does have 3 ribs on the left side of the pan.
It looks correct to me as well, I have a L46 Pan and it does look the same. The easy way to recognize the performance pan is the drain plug is on the rear of the pan. Good luck the pans seem to be prone to leaking between the dipstick area and the last rear bolt. I am trying to replace my pan and cannot find one.
