Ground clearance
Good luck
Larry
When loading the car, try and have the trailer axles in a dip or low spot in the area your loading in. Try and make the ramp/loading deck transition as level as possible.
Put something under the outside rear corners of the trailer when loading. As you drive up you'll be putting a surprisingly large amount of UPWARDS force on the hitch ball and only a small piece of light metal holding the trailer on the ball. You dont want to damage your tow vehicle. Notice how much the back of the tow vehicle rises when you drive on the ramps? Put something under the back end of the trailer frame. This wont allow the full weight of the car to potentially pop the trailer off the hitch. Use a piece of wood on end, like a 4x4 or 6x6. Might have to stack a few pieces together. Allow for the trailer springs to compress some, dont get the wood pieces stuck under the trailer with the full weight of the car on it, if you do, strap the car down and pull the trailer off the "braces", no big deal.
Oh yeah, take more straps than you think you'll need. I have five 5000#, 14' long ratchet straps with me all the time. I use four to hold the car and one spare. I cross strap and cross front to back. LR strap attached to the frame is attached to the RF "D" ring on the trailer, etc.
The Uhaul rig might come with webbed tire straps. They may work fine, but depending on the car they might not fit over the tires.
dodosmike
EDIT: Depending on the car and road conditions I've seen a few people on the forum get some pallet wrapping, (that clear stuff you see wrapped around boxes/bags of stuff on shipping skids) and wrap the car in a bunch of layers. Helps protect the paint and windshield from stones and road debris. I guess it really depends on the car, Parts car, no worries, a nice driver, it might be worth it.
I am renting a u-haul trailer… and have watched this video. http://www.uhaul.com/Articles/Tips/3...aul-car-hauler
I don't understand you… could you elaborate on where you would use those straps?
https://www.corvetteforum.com/forums...with-pics.html
Light reading.
Visualize an "X" under the car:
I dont know if the uhaul rig will have D rings or not.
dodosmike
EDIT:
Looked like an SUV (Mercedes maybe) pulling that trailer. I will have a '13 Dodge Ram 1500.
Don't put any loose fitting covers on the car, they flap in the wind and beat the paint up.
Watch where you drive and you shouldn't need to worry about flying rocks.
The U haul trailer will have front tire straps and in the rear I've looped a strap around the collapsible impact tubes between the rear bumper and body and criss crossed them to the tie downs on the trailer.
Good luck!
