So I decided to give my new 75 a quick rinse to wash off the rain from the last few days and found some water sprayed into the interior. I look around to find the source and it isn't the t-tops. I look up and see a poorly spread on glob of silicone. Apparently bubba had a leak and decided to slap a patch on.
So that brings me to my question. What is the most bubba fox you have come across?
I have 3" framing screws holding my interior door panels on. Two of them have black painted washers...like nobody would ever see them.
Needless to say, the door panels are my next interior upgrade after the leather seat covers go on.
Is a "Bubba Fox" like a "Car fox" or did you just "Bubba" your own post....
When Bubba found out that the power window arm were a bit floppy he fixed it why welding them together a the joint, like this :
It was a mirable the window motor could still actuate them (well it would blow the fuse every other attempt).
That's how I discovered how powerfull those motor were, because when out of the door, I had to hammer them to make them move.
My oil filter was on so tight that I could barely get it out after putting a long screwdriver through it and using anything I could think of to get it off. I think he thought the leaking valve cover gasket was the oil filter leaking.
One of my headlights (the large floodlight looking bulb) is loose. Spent 45 minutes under the car trying to seat the benzel and bulb. It will not seat, I think there is a small metal tab missing. I see one and tried to bend it so it holds the benzel better. No luck. Slapped a neatly cut piece of duc tape in there and called it done for now. Its on the backside of the bulb and invisible to other Bubba's....
