76 vette fuel line replacement
Old Jun 2, 2015 | 04:09 PM
Parks76's Avatar
Parks76
4th Gear
Default 76 vette fuel line replacement
Hi guys. Im new to the site and just bought my first vette a 76 f4om my brother in law. My question is this. My brother in law replaced the fuel line from the tank to the engine with rubber hose. I am changing that asap. Has anyone used braided flexible line for that. It is body on resto. Thx
Old Jun 2, 2015 | 04:22 PM
toobroketoretire's Avatar
toobroketoretire
You say he replaced it with a "rubber hose" but it was likely internal braided fuel hose.
Old Jun 2, 2015 | 04:33 PM
Parks76's Avatar
Parks76
4th Gear
Im going to check when i get home. But, he im pretty sure he seriously half ***'d it and its just standard hose.
Old Jun 2, 2015 | 06:12 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Fiberglass, gasoline, and rubber hose is a recipe for a fire ball,
bite the bullet and do it right, put in a replacement steel line.
Old Jun 2, 2015 | 06:47 PM
'75's Avatar
'75
Some of the braided fuel line that others here used, had problems with gas leaking through the walls of it and leaving a strong gas odor. Steel line is the best, you can get replacements for a reasonable price, but installing them in one piece without lifting the body is hard. You could cut and re-flair it to make a joint at the rear kick up area.
Old Jun 2, 2015 | 09:19 PM
76vette1's Avatar
76vette1
I used a place called Inline Tube for prebent SS fuel lines. Worth it in my book.
Old Jun 2, 2015 | 10:38 PM
Parks76's Avatar
Parks76
4th Gear
So i checked out the fuel line (rubber hose). It is sae30rkx. I researched it and it is fuel line suitable for this application. However i think im just going to run steel lines as best i can, hopefully just 2 pieces 1 join over the run. Even if i end up with 2 joins i think i am far better off with the steel lines. Thanks guys
Old Jun 3, 2015 | 07:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...do it right, put in a replacement steel line...
I agree.
...i think im just going to run steel lines as best i can, hopefully just 2 pieces...
Order a stock replacement fuel line.
Old Jun 3, 2015 | 12:47 PM
Jazzyced's Avatar
Jazzyced
go with steel.
the 2 rubber hoses I have between the tank and the line itself leaked badly a month ago and scared the s@### out of me!
Fuel dropping on a hot exhaust = fire...
I got really lucky.
2 weeks after the rubber hoses between the filter and the carb did the same...
I was lucky again, no fire.
They all said SAE30...but age and heat does not treat them well.
Needless to say, I am replacing these hoses with proper steel lines asap.
Old Jun 3, 2015 | 02:45 PM
scrappy76's Avatar
scrappy76
For starters, your brother inlaw is the ultimate " Bubba" , for doing that. You have to replace it with metal lines A.S.A.P
To 76 vette fuel line replacement
