backspacing help
Old Jun 4, 2015 | 10:58 PM
newc3's Avatar
newc3
Default backspacing help
going to order torq thrust II wheels, 15x8's. the backspace is either 4.50 or 3.79 which backspace should I get?
have 255/60r15 tires on the front and 275/60r15 tires on the back
78 vette
Old Jun 4, 2015 | 11:09 PM
GaToy's Avatar
GaToy
The 3.79 would stick out more but you wouldn't have any problems with the parking brake brackets.
Old Jun 5, 2015 | 12:37 AM
cagotzmann's Avatar
cagotzmann
78 vette
Neither stock 15x8 wheel is 4" Backspace. I have seen people claim they have those wheels with 4" backspace.
One will sit in too far and need an adapter to move the wheel out, the other will stick out.
4" backspace on the 15x8 is -12mm offset.
Old Jun 5, 2015 | 01:06 AM
newc3's Avatar
newc3
just not sure which wheels to order. those were the 2 choices
Old Jun 5, 2015 | 02:31 AM
TCracingCA's Avatar
TCracingCA
Default a number of things would need to happen to run 4.5 related to clearance
the 275 on a stock fender is pushing it on a 3.75 rim
Old Jun 5, 2015 | 12:25 PM
The Punisher's Avatar
The Punisher
If you go with the 4.5 you will have to relocate the emergency brake brackets that holds the cable. And also with a 275 tire you still may need a wheel spacer of about 5/16". Then with adding the spacer its quite possible you will need longer wheel studs depending on the wheel design.
I went with a 17" torque thrust 2 with a backspace of 4.07". didn't require any modifications
Old Jun 5, 2015 | 12:34 PM
newc3's Avatar
newc3
It sounds like going with the 3.79 would be easier, I don't mind if it sticks out! I think I'll measure the stock wheels and what the back spacing is now
Old Jun 5, 2015 | 12:37 PM
newc3's Avatar
newc3
And a 255 and a 275 tire can go on a 15x8 wheel?
Old Jun 5, 2015 | 02:35 PM
red topless gator's Avatar
red topless gator
Same thing here
Old Jun 5, 2015 | 02:53 PM
ddawson's Avatar
ddawson
You want a 4" backspace or -12MM offset.
Old Jun 5, 2015 | 11:46 PM
newc3's Avatar
newc3
well they only had 4.50 and 3.79 so I went with the 3.79, hope it works out
Old Jun 6, 2015 | 05:01 AM
The Punisher
If you get a tire like a 235 it won't over hang the rim and may be closer to the edge of the wheel well. Just guessing Good luck
Old Jun 6, 2015 | 04:42 PM
The13Bats's Avatar
The13Bats
It will...
Old Jun 6, 2015 | 10:14 PM
newc3's Avatar
newc3
Thanks guys
Old Jun 11, 2015 | 09:18 PM
newc3's Avatar
newc3
well I placed an order at Tdot last thursday for the wheels, got an email sunday saying they have to contact american racing 1st thing monday to "check for proper fitment" on my vehicle.
Haven't heard anything since, and no response to emails... think I just got screwed
Old Jun 11, 2015 | 10:44 PM
gjohnson's Avatar
gjohnson
What you bought will stick out 2 tenths of an inch over the stock 4" bs. Hardly noticeable.
To backspacing help
