differential front support not lining up?
anyway I heated up the bent/elongated hole on the support flat again and decided I'd deal with it later. I reinstalled the rear tonight & of course the support bolt does not line up with the hole (for got about it)? It's almost a full bolt width off? there is no obvious evidence of a bent frame as everything under the car looks square & symmetrical. Its like the rear is off towards the drivers side or the diff support is bent to one side or the support that bolts on the differential nose is bent but nothing looks odd or out of place.
I am thinking worst case , bent rear frame but I would think I'd see something with the rear that far off, a repair,frame wrinkles, something?
Paul
Brian
Paul
1. from the driver side diff crossmember bolt to the diff carrier hole
2. from the passenger side diff crossmember bolt to the diff carrier hole
these should be equal measurements to the center of the diff carrier hole.
Does the diff look centered in the crossmember ?
Any chance the diff carrier braket is the bent item ?
although the center frame support was elongated (the hole) to the driver side, that frame mount itself looks square & centered with good factory welds. the rear bolts on & seems to sit square against the cross member. the cross member go right onto the alignment pucks on the upper frame and when installed the cross member is parallel/squared to the cross frame behind it (not cocked or angled).
I will try your measurements today, not sure if you want the frame points or the same points on the rear diff assembly. I will try both & post my findings later?
Not sure if the drawing I found is accurate but even in that drawing the CL of the car is off center from the differential support about as much as mine looks? maybe my differential support bracket is bent?
almost seems as though I have to open the cross member holes .500" to one side & slide the differential over then re torque?
Paul
not sure what this would do as the leafs are hanging in the air & not connected to anything right now. my only fame connection is with the 2 bolts going through the cross member up into the upper frame.
Okay, then loosen the four 3/8" NC bolts that bolt the crossmember to the top of the rear end then swing the nose around. The bolts are hard to get to but you CAN get to them with some effort with a 3/8" breaker bar and short 9/16" socket. Just be sure to re-tighten them.
I just wasn't sure if there was enough play in the cross member holes to allow it? I will end up trying it, but I did find a member close by that had a differential support for $30 so I bought it off him. looking at mine it may have a slight twist in the front pad? it's worth it to me to rule out that piece for $30 .
thanks.
Paul
after re-trying this over & over (about 7 times) I called it quits for the night. today after 10 hours at work i had somewhat fresh eyes and noticed 2 things. the frame seems square, as far as using a tape measure (by yourself) and measuring what you can. It seems parallel side to side as well? I decided to use a Verneer to check the distance from the center of the bolt on the cross member mount to the center of a factory punched hole in the main frame cross member that is behind the differential cross member. the passenger side is 5/16" off, from the drivers side, so one side it kicked forward (passenger side) or one side is kicked back (drivers side)? which would throw the differential nose towards the drivers side. I also found that when the car took what ever hit it had, it must have got the edge of the cross member as it has evidence of the corner being torn back (on an angle towards the center of the car). And the front sheet metal support that used to be welded to the main side frame from the rear cushion retainer, is gone, the retainer is there but i think it was pushed or bent forward and someone cut or ground off the sheet metal support that used to come from the front to the main frame?
So heres my question,is there a way to move that rear cross member cushion retainer back 5/16", while in the car/body on. or do I leave that alone and open the 4 cross member holes up to enable me to get the last bit I need to center the rear?
I assume I can buy an new sombrero(retainer) and frame mount to weld in, I hope!
Paul
other then that the car runs and has all the correct pieces and is worth saving but I have no intention of taking the body off. I will be replacing the diff center mount with new poly pieces as well as new shocks,rebuilt trailing arms,new adjustable lower struts,new brakes/calipers & lines,all new u-joints etc. so the whole back end is new so this problem is my hurdle from putting the car back down on the ground.
thanks for any and all input!
Paul
Paul
Unless you can pinpoint whether something is bent or not square. You do want the nose to driveshaft as inline as possible. I doubt that the nose mount on the frame would have been bent, but there is always the possibility that that entire crossmember where that mount welds too is tweaked if you aren't seeing it at the rear diff crossmember. Do the brake lines look Ok? I now insist that you not even loosen the cushion bolts like I suggested a minute ago and start really checking to see if that is square. I would prefer to not have the rear diff off at an angle, even if it essentially runs through halfshafts and a driveshaft and there is some flexibility of the rear spring mounts.
Do what you can to identify if you are square, but honestly also-- you don't look too far off to me, so I feel that distance with a little wiggle of the rear end crossmember on one side smacking it with a mallet should get you that distance, but then I don't want you crossthreading the cushion bolts either, so leave those well engaged if it comes to that!
I need to find a member that has a good frame to measure some center lines off there frames so i can compare it to mine using factory frame spots (see pic).
all of my brake lines & fuel lines were original & still factory "straight" alone the frame. as stated above I even got another cross member thinking mine was bent and still had the same outcome so I think my problem is in the 2 retaining mounts since they position the diff. also tried another differential front mount in case mine was tweaked, same problem.
I will post my finding later tonight.
Paul
measurements I need:
here is the other post from this weekend:
https://www.corvetteforum.com/forums...surements.html
here are some frame measurements I did with a tape measure laying under the car (so it's not pin point laser geometry LOL )
Does someone have the hole OD for him also??
is this the measurement you want me to take?
i also presumed that the drive train was offset to the passenger side on c3's and would account for the different angled measurements?
what puzzles me is if the frame is bent, wouldn't the body mounts (all or some) be off just like the differential mount was? all the (visible) body mounts are straight , not jogged or at any angles ,and centered on there mounts? also no obvious signs of body cracking or distortion. all the original brake & fuel lines were in there factory installed positions with no signs of replacement or re-bending from a hit etc
