Flooding Holley
Old Jun 11, 2015 | 09:44 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Default Flooding Holley
I had the original Holley carb for my 72 LT-1 rebuilt a few months ago after which it ran reasonably well. The car sat for a few months and when I started it last weekend after about 30 seconds gas started running out of the rear bowl vent and the engine stalled. I have changed out, one at a time, the rear float, the needle/seat assembly and the power valve. None of these helped. Does anyone have any suggestions?
Thanks.
Old Jun 12, 2015 | 04:00 AM
toobroketoretire's Avatar
toobroketoretire
Thanks.
Is the little o-ring on the needle seat in good shape? If that o-ring is damaged gasoline will fill up the bowl and the needle can't stop it.
Old Jun 12, 2015 | 07:53 AM
dan1495's Avatar
dan1495
The o ring looks fine, but I tried another needle and seat and the symptoms were the same. Thanks for the reply.
Old Jun 12, 2015 | 08:35 AM
pltmgr's Avatar
pltmgr
One time when I replaced a float I accidentally bent it resulting it moving freely when the bowl was off the carb but it would hit the metering plate when installed. Another time when I replaced the power valve the gasket was slightly askew, causing major flooding. Both times I fixed one problem but created another.
Old Jun 12, 2015 | 04:18 PM
Les's Avatar
Les
Until you get it sorted out you'd better be very careful not to have a cylinder fill up with raw fuel while turning the engine over. Not only is it not good for your rings to be washed with fuel, but you can experience a hydraulic lock. This is where the engine can't turn over because the fuel has filled a cylinder and been trapped with both valves closed. When it locks with the engine spinning it can hammer the rotating assembly, doing damage requiring a tear down. If you think you've dumped much raw fuel into the cylinders you can pull the sparks plugs to let the cylinders drain and dry out. Squirting a little oil into the plug holes before firing it up would help re-lube the cylinder walls with oil. Good luck.
Old Jun 12, 2015 | 04:31 PM
dan1495's Avatar
dan1495
I was worried about that too. At the first sign of gas coming out of the vent I would shut it down, remove the carb and soak up any residual gas in the intake with a rag. I have another carburetor I am going to run until I figure this out. I'm going to change the oil and filter as a precaution. Thanks for the reply.
Old Jun 12, 2015 | 05:21 PM
Les's Avatar
Les
I was worried about that too. At the first sign of gas coming out of the vent I would shut it down, remove the carb and soak up any residual gas in the intake with a rag. I have nother carburetor I am going to run until I figure this out. I'm going to change the oil and filter as a precaution. Thanks for the reply.
To Flooding Holley
