Jumped in the deep end...My '75 coupe
Welcome & congrat's I have a similar 75 coupe white/blk. C3 's are great drivers & fun to cruise around not that many on the street. Tonight we went to get ice cream T tops off of course.
Good luck
Mine sat for 19 yrs took several months to get it going
Good luck
NICE! That's what we do with C3's
3rd pic. look at the brake pedal pad. now lift door up while open. if car has 165 on it, the hinge pins will have slop, and somebody replaced the brake pedal pad. this car has 65k. when any car from mid 70's has 150k+ on it, it is a rattletrap that needs everything redone.
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Very nice. You're moving along rather swiftly.
I also have a white 75 auto coupe. I'm in the process of converting it to a 4 speed.
I always wondered what my 75 would look like with a luggage rack. I like it.
Make no mistake, it needs a lot of work. The paint is a mess. But it sat outside a long time. It needs some love. I'm trying to give it some.
Making some progress. One thing just leads to another, though.
After I got the front bumper pulled, I figured I might as well clean up and repaint the support structure behind it. And while that was off, it's a good time to rehab the headlights. Lots and lots of parts to pull off, de-rust, wire wheel, primer, re-paint, put back together, and re-install on the car.
Half way done with the headlight modules.
The actuators are still in good shape. Just had to clean them up and replace the rubber boots.
I'll be taking more pics as I put things back together.
Long ways to go!
Long ways to go!
Long ways to go!
Long ways to go!
ZIO
the rubber headlight vac hoses are 40 years old. change them out, or at least cut half an inch off each end so they hold to their hose nipples better. lot of progress for a couple of months. sway bar bushings, idler arm, and especially the bushings where steering ram attaches to the frame.
In addition to trimming the hose ends a little, I used spring clamps on the actuators and the vacuum reservoir lines. Unable to do that on the relays. Why did chevy make the top and bottom ports oval instead of round???
Making some progress...baby steps!
New upper radiator hose....which lead to removing the t-stat housing to get that cleaned up. It was rusty and pitted and I thought I'd have to go buy a new one, but after soaking overnight in rust remover, it's still solid. I took my wire wheel and grinder to it to get it back in decent shape, then shot a coat of clear over it to keep it looking good for a while.
I also found that the previous owner had removed the t-stat. Installed a new 180 degree unit.
New power steering belt of the correct length. The old belt was a bit too short, which left the steering pump pulled in towards the engine block and the cap to the pump directly under the alternator bracket. Had to remove the alternator to add steering fluid! Now, it sits correctly with the cap accessible outboard of the alternator bracket.
New transmission seal and filter. That was fun. Note to self: Never remove all the pan bolts, even if the RTV seems to be holding it tight.
As soon as I started prying the pan loose, it fell and douched my garage floor with ATF. That took a while to clean up!!!
Best for last, fixed the leaky power steering control valve. Installed a rebuild kit, put it back together, added fresh fluid, turned the steering wheel lock to lock a couple times and no leaks!
Sooooo many more things left to do.
Still moving forward....slowly.
Got the front and rear bumpers installed temporarily, just to see how things line up. They will need some massaging, but it's nice to have a face and a butt on the old girl.
Had a pretty serious brake caliper leak on the right front, so I pulled the caliper off to refurb it with new seals and brake hoses...and hell, while I've got that off, might as well put new ball joints on....going to be fun drilling those out, and the A arms look like hell, might as well pull those and install the new bushing set I've got sitting in the garage...can't put those new bushings in rusty old A arms....etc., ad nauseum.
But hey, now I've got a brand new Harbor Freight blasting cabinet to clean up all my greasy, rusty parts!!! That's already speeding things up.
Progress is good!
Progress is good!
#33
Looking great!! It's always the "might-as-wells" that get you.
Wonderful progress.
Wonderful progress.
#35
Great progress, mine was originally white also with 50k on the odo. I originally thought it was 150k till I took the engine apart, original number matching with virtually no cylinder wear.
#36
That "while I am here" is a nasty disease! But you are making it SHINE!! Good deal keep up the good work!
#37
#38
