Tensioner pully
On second thought, that might not work- the pulley diameters need to be kind of matched between the first and second grooves. And if you're going for show points, it's not original for your year.
A bit like a jigsaw puzzle . Especially if you didn't have one to take off
I was nervous , would I get everything back exactly like it came off .....lol
The gaps between some items it like 3/16 of inch or less.
Knowing how crap is so cheaply reproduced today....about half azzed to boot .....as most seems ..I d be surprised if repop stuff would line up right.
Anyway a wrong or too thick or too many washers in the wrong spot might cause odd wear , rub, noise ...etc..
And .....don't crank back on it too tight. The bearing is kinda small inside the idler
I remember it not being a lot of fun .....I replaced my water pump has all that crap off........pita
