Side Exhaust - Rocker Panels Question
Old Jun 22, 2015 | 05:21 PM
nivensid's Avatar
nivensid
Default Side Exhaust - Rocker Panels Question
My 78 did not have the rocker panel installed when I purchased the car. I have since then removed the 69 style side exhaust which required the panels be removed and installed the OBX/Maximizer headers and sde exhaust.
Now I need rocker panels and I have them on order. Can anyone who has the same brand exhaust let me know if any modifications were necessary to install the side covers after the exhaust?
Any pics to show off your OBX/Maximizer exhaust, that would really help out.
Old Jun 22, 2015 | 06:44 PM
havesometo's Avatar
havesometo
You have to jack your car up and remove the rear tires and slide the rocker panel in from the back. I had to trim a little off of the front bottom of the rocker panel on passenger side. What I've read in the past it depends on your car. You may not have to trim yours.
Old Jun 22, 2015 | 08:08 PM
nivensid's Avatar
nivensid
Thanks, it looks like the mounts for the side tubes that bolt to the frame would interfere with the rockers? My panels should be in this week then I will have a better understanding. My wife tells me all the time I like to over think things too much .....
Old Jun 22, 2015 | 08:52 PM
havesometo's Avatar
havesometo
The mounts will not interfere with them. Did you order your mounting bolts?
Old Jun 22, 2015 | 09:14 PM
nivensid's Avatar
nivensid
They came with exhaust look identical to these by Hooker.
Old Jun 22, 2015 | 09:21 PM
havesometo's Avatar
havesometo
Interesting my OBX did not come with them. I ordered the hooker ones.
Old Jun 22, 2015 | 09:29 PM
nivensid's Avatar
nivensid
Mine are Maximizer but from what I read on here they are the same company. Did the OBX not come with any bolts at all?
Old Jun 22, 2015 | 09:40 PM
havesometo's Avatar
havesometo
No the OBX did not come with mounting bolts. I remember your car now I complimented you on your heat shields. Your car looks good too. And you sent me a private message.
Old Jun 24, 2015 | 12:23 PM
nivensid's Avatar
nivensid
Default Rockers Installed
I was able to get the passenger side rocker panel installed today before work. As mentioned before I had to cut off about 1/2" from the side tube mounting bolts but no trimming was necessary to the rocker panel. I did remove the rear wheel but in this case it was not necessary. Next on to the driver's side maybe this weekend when I have more time.
Old Jul 1, 2015 | 01:13 PM
bluegtp's Avatar
bluegtp
Looking good......see signature for pics......I did have to remove my rear tires to put the rocker panels back on. OBX install was pretty straight forward minus a couple of bolt holes I had to drill out and ding the headers in a few spots for clearance. On the other hand I didn't have to cut up my brand new rocker panels to fit the headers, very very close though. Hopefully yours doesn't rust or corrode like mine do!
good luck!
Ryan
Old Jul 1, 2015 | 02:12 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
My mount bolts had to be shaved some due to them bumping against the back of the rocker moulding. It was really no big deal just dont shave too much!!!
To Side Exhaust - Rocker Panels Question
