Help with body prep materials and procedures
Old Jun 24, 2015 | 09:29 AM
FM73project's Avatar
FM73project
Default Help with body prep materials and procedures
New member restoring a 73 coupe. Can someone help me with the proper materials and procedures to prep my car for paint by a professional. Im in the process of doing a frame off restoration and would like to prep the fiberglass body myself (somewhat of a perfectionist) Thanks.
Old Jun 24, 2015 | 10:08 AM
530planeman's Avatar
530planeman
Default Prep
To start with I had mine Baking Soda blasted then I could see if any Bubba repairs were done over the years.Easy to clean up and saves a lot of sanding and don't have to tape anything off
Old Jun 24, 2015 | 10:48 AM
FM73project
Thank you, that's good advice sounds a lot better than a razor blade.
Old Jun 24, 2015 | 08:21 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Post this up in the Paint/Body section.. Lots of good advice and help there.
Old Jun 24, 2015 | 08:54 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Do a YouTube search for Eastwood. They have some great videos about body prep. A lot of it is for metal cars but they do have Fiberglass specific how-to episodes too.
Old Jun 24, 2015 | 09:12 PM
SB64's Avatar
SB64
Default Body Prep
In the process of prepping my car which I will prime as well as paint. Most of my info has been coming from Dub a professional with his shop in Charlotte. I used a heat gun to remove the paint, light sanding and lacquer remover to obtain the raw fiberglass. I would agree to make your post in the body and paint area. I have also fabricated all my repairs as a novice.
R
Questions??
Old Jun 24, 2015 | 10:45 PM
Sunstroked's Avatar
Sunstroked
I too prepped my car for final paint. I paid a pro to lay down the final color and clear. I learned something from spraying all that primer.
Im not a very good painter, and after all that work prepping I wasnt going to waste money and screw it up.
I used the razor blade and heat gun method to strip paint. I used west systems epoxy and 3m glass mat to do repairs, and evercoat vette filler and body panel adhesive. I did use SPI epoxy primer and 2k primer.
I did a pretty good job, the painter only found a few areas where he felt needed his attention.
Its very time consuming, dirty, and requires a lot of patience. I wouldnt do it again unless I had a detached garage. I was lucky that when I began all the major grinding etc, I lived in a rural area and just pushed the body on its dolly out into the driveway for most of the heavier work.
it turned out pretty good.
Old Jun 25, 2015 | 08:28 AM
FM73project
Thanks for all the great advice. I'm a builder by trade and a perfectionist. I love taking something that seems to be beyond repair and bringing it back to its former glory, but I realize how easy it is to miss that one crucial step. I've been told it's better to apply a gelcoat before final paint any advice?
Old Jun 25, 2015 | 08:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I've been told it's better to apply a gelcoat before final paint any advice?...
Factory panels had no gel-coat. You do not need it. Any good quality primer/surfacer serves the same purpose.
Old Jun 25, 2015 | 08:42 AM
FM73project
Old Jun 25, 2015 | 08:45 AM
SB64's Avatar
SB64
I have been told a good polyester primer would be the way to go and as such that's what I will do- FYI
R
Old Jun 25, 2015 | 09:04 AM
FM73project
I purchased an epoxy primer to protect the bare fiberglass, was that necessary?
Old Jun 25, 2015 | 12:36 PM
SB64's Avatar
SB64
Hi fm73project, as far as I know yes you will need that to prime the car. I also believe the gun needs at least a 2.o tip. Depending on what you purchased may dictate the tip.
R
Old Jun 25, 2015 | 01:52 PM
corvetteronw
Cruise-In VIII
Old Jun 25, 2015 | 02:38 PM
Easy Mike's Avatar
Easy Mike
...I purchased an epoxy primer to protect the bare fiberglass, was that necessary?...
Epoxy may not have been necessary, but almost every surface to be painted needs primer - bare fiberglass included. If you want to use gel-coat, apply it over bare fiberglass. That done, prep it and shoot primer coats over it.
Old Jun 25, 2015 | 03:02 PM
13611's Avatar
13611
All good advise here and if you go into the paint and body section you'll get even more... mostly from guys who do it for a living. If at all possible, avoid the soda blasting of your vette. Most professionals won't touch your car if they know its been soda blasted. Have them use walnut shells or some soft plastic media. Hidden soda will ruin a paint job. Good luck to you.
Old Jun 25, 2015 | 03:33 PM
dochorsepower's Avatar
dochorsepower
One other little thing that's not so little if you make the mistake. DO NOT use paper towels to do any solvent wiping cleanup. Paper towels have release agents which make them easy to manufacture but will contaminate your paint surface. Yes, I speak from experience. Use freshly washed, soft cotton cloth or towels.
To Help with body prep materials and procedures
Old Jun 25, 2015 | 04:34 PM
530planeman
Default Paint and body section
Could you direct me to the "paint and body section"
Old Jun 25, 2015 | 04:37 PM
13611's Avatar
13611
In the forum drop down menu go to General Corvette Topics then go to Paint and Body. Put a link to this thread there as well.
Old Jun 25, 2015 | 04:38 PM
13611's Avatar
13611
Between now and 3'ish is usually when at least one of the pros is on there.
