What is it ??
Old Jun 24, 2015 | 03:06 PM
1978vett's Avatar
1978vett
Default What is it ??
There is a part underneath the coil in my 78 .. It looks like a spring that connects the coil to the distributor.. Can someone tell me what it is called,, i'm hoping to replace it and didnt know what it is and if I can just buy it by itself ?/
Old Jun 24, 2015 | 03:25 PM
Giant_Robot's Avatar
Giant_Robot
a spring.
Old Jun 24, 2015 | 03:39 PM
1978vett's Avatar
1978vett
Originally Posted by Giant_Robot
a spring.
Thanks ,,that helps a lot..
Old Jun 24, 2015 | 03:53 PM
oldgto's Avatar
oldgto
Old Jun 24, 2015 | 05:23 PM
blue by you's Avatar
blue by you
how about a picture of what and where it is
Old Jun 24, 2015 | 05:37 PM
1978vett's Avatar
1978vett
Thanks ,but I got it figured out,, It's a small spring that comes with the distributor cap,, it is in the compartment that the coil sets in ..
Old Jun 24, 2015 | 05:52 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If you had been a little more specific, in your original post, we could have helped you more readily.
It appears that the part you're referring to, is the contact bushing that is in contact with the center of the distributor rotor. The bushing sits in the hole of the cap, the rubber gasket goes on next, with the spring protruding through, followed by a coating of dielectric grease on the gasket, then the coil is installed, holding everything in place.
Old Jun 24, 2015 | 06:31 PM
tokim's Avatar
tokim
^^This^^
NAPA sells this separately- Distributor Cap Resistor Brush part #RR196
Old Jun 24, 2015 | 09:47 PM
1978vett's Avatar
1978vett
The following is what I posted,,I don't know how a person can be more specific than that when asking about something that they dont know anything about.. There is a part underneath the coil in my 78 .. It looks like a spring that connects the coil to the distributor.. Can someone tell me what it is called,, i'm hoping to replace it and didnt know what it is and if I can just buy it by itself ?/
Old Jun 24, 2015 | 09:50 PM
1978vett's Avatar
1978vett
Originally Posted by tokim
^^This^^
Thank you for your reply,,,
To What is it ??
