I'd hang the upper arm with the spindle, then the lower arm and spring. When the lower arm goes up with the spring, you already have the upper arm and spindle to catch it.
Upper arm,
spring held in place with compressor! Make sure it's seated in the top pocket.
Lower arm with jack under it.
Install spindle on lower arm and raise the jack
Install spindle to upper arm
Tighten ball joints and release the compressor.
