Shifter console wiring question....'72
Old Jun 25, 2015 | 10:24 PM
Wee's Avatar
Wee
Default Shifter console wiring question....'72
'72 4 speed with A/C if that makes a difference....I'm pretty sure none of these wires were plugged in anywhere when I took the console out. I have the AIM and wiring harness schematics but still can't figure them all out. First pic....Wire seems to come from under the gauge console....?
Second pic I can't figure out the double purple wire....? I think I have the other 2 figured out.
Brian
Old Jun 25, 2015 | 11:03 PM
Mooser's Avatar
Mooser
The purple and purple / white are for the neutral safety switch if an automatic trans was installed
M
Old Jun 25, 2015 | 11:44 PM
Sunstroked's Avatar
Sunstroked
M
And clutch safety sw with a 4 spd.
The black, black & white I do believe is your ammeter wire.
I cannot tell you how many hours I studied these diagrams putting my 72 back together. And the really bad part is I would figure it all out, then delay hooking anything up and have to figure out where they all went again. Lol.
Old Jun 26, 2015 | 06:38 AM
Gordonm's Avatar
Gordonm
The gray wire is not a cig lighter. That is usually an orange wire. The gray wire is used for console lighting.
Old Jun 26, 2015 | 07:43 AM
Mooser's Avatar
Mooser
I think he's meaning the light on the side of the cig-lighter
M
Old Jun 26, 2015 | 09:00 AM
gkz's Avatar
gkz
An extender connects to this gray wire, which illuminates the PRND21 (on AT).
Old Jun 26, 2015 | 12:03 PM
Wee's Avatar
Wee
So since I have a 4 speed the purple wire will not be plugged into anything....?
Brian
Old Jun 26, 2015 | 04:53 PM
Mooser's Avatar
Mooser
Brian
Only for the auto's
M
Old Jun 26, 2015 | 06:25 PM
Gordonm's Avatar
Gordonm
My bad. Yes with a 4 speed the purple wires will not be connected.
Old Jun 26, 2015 | 11:14 PM
Wee's Avatar
Wee
Thank Ya'll for the help....I had to drop the gauge console to get the ammeter wire connected back up.....I thought I could just reach up in there and hook it back up.....Yea right. About the only screw that was actually holding much was the top center screw, all the side screws just spun in there holes. I had to use bigger screws to put it back together, but between them and the radio brace I made it fits much better than before.
Brian
To Shifter console wiring question....'72
