Need some advise
Old Jun 26, 2015 | 02:44 PM
1978vett's Avatar
1978vett
Default Need some advise
Last weekend My 78 was running fine , we had it out all weekend.. Monday it wouldn't start.. It turned over but would not start,, it was getting fuel but no spark.. First thing I thought of was the control module in the distributor,,so I replaced it and then it fired right up. I went for a short ride and noticed right away that it wasn't accerating good, and would backfire through the carb if I gave it to much gas,so I thought maybe the coil was bad from the module going bad,, changed that and the capacitor/condensor,cap and rotor too.. Still doesn,t run right. It starts good but boggs under load... Does anyone have any advise on this ?? It has a quadrajet carb on it,I'm wondering if something went wrong with it.. Sorry for the long post..
Old Jun 26, 2015 | 02:52 PM
530planeman's Avatar
530planeman
Sounds like something got into accelerator pump in carb and you are getting a lean backfire .
with engine off look down carb and pump throttle you should see q fair amount of gas squirt out in both sides of carb.
Old Jun 26, 2015 | 03:08 PM
1978vett's Avatar
1978vett
It looks like it is getting gas on both sies of the carb.. When I drive it ,, it feels like it isn't getting enough when I accelerate.. Seems like the more gas i give it the more it feels that way..
Old Jun 26, 2015 | 03:20 PM
530planeman
Does your dist. have a vacuum advance on the side of it ?
Old Jun 26, 2015 | 03:27 PM
dochorsepower's Avatar
dochorsepower
You don't say what carburetor you have. If it's the original type Q'jet, check the inlet fuel filter. Best to be safe and replace it anyway.
Sorry I didn't read carefully. OK, you have Q'jet. Yes, replace inlet filter.
Old Jun 26, 2015 | 03:37 PM
1978vett's Avatar
1978vett
Yes it does, and if i un hook it the idle drops.
Old Jun 26, 2015 | 03:38 PM
1978vett's Avatar
1978vett
Wont be able to do that today but will do that, Thanks
Old Jun 29, 2015 | 12:25 PM
1978vett's Avatar
1978vett
I put a new fuel filter in today, and it didn't help.. It was worth a try.. Could vac. advance cause it to bog down ??
Old Jun 29, 2015 | 12:50 PM
530planeman
It could I mentioned that a few reply's back .You can remove dist cap and (if you don't have a vacuum Pump) suck on the hose going to vac. advance and dist plate should move around counter clockwise
Old Jun 29, 2015 | 01:05 PM
1978vett's Avatar
1978vett
Thanks, I'll try that. I did pull the vac advance hose off with the motor running and the rpms dropped, Woukd that mean the vac advance is working ?
Old Jun 29, 2015 | 01:50 PM
74modified's Avatar
74modified
Ok - It was running fine then had no spark, so a new module fixed it. Now you have bogging.
I would not start digging into other things until I checked things associated with the last change – timing, coil, module, & firing order (if you removed any wires). The chance of two things breaking at the same time is kind of slim. I have also had new modules that were bad, and ran crappy, right out of the box –even Delco & Delphi brand, not just discount. The carb was running fine before, stick with ignition things first until you rule them out.
Old Jun 29, 2015 | 03:00 PM
1978vett's Avatar
1978vett
I'm on the second module since this happened, new coil ,condensor,rotor and cap. Timing was fine before , plug wires went back on just like they came off ,,
Old Jun 29, 2015 | 07:31 PM
1978vett's Avatar
1978vett
Does anyone know what thw black wire that I am pointing to is for, I noticed that it was backed almost all the way out of the alternator and the connector was loose and probably not making a good connection.. I tightened it up and went for a ride and it runs perfect...
Old Jun 29, 2015 | 07:34 PM
530planeman
Ground wire
Old Jun 29, 2015 | 08:05 PM
1978vett's Avatar
1978vett
Ground wire
It must ground the ignition system some how, it was running bad,,bogging down and backfireing until I tightend the bolt..
To Need some advise
