Temp control vacuum leak
Old Jul 4, 2015 | 11:45 AM
Tommy79's Avatar
Tommy79
Default Temp control vacuum leak
Just got a 1979 a couple of weeks ago and getting accustomed to it. today, I move the control for the air conditioning and set it to heat. Just to test it. When I stopped, I hear a loud vacuum leak from the console. Sound goes away when in the cool mode.
Accessing the control, I started the car and moved the temperature control and could hear the air leak from the part that has 4 or 5 vacuum lines connected to it.
Note: Air works fine and my headlights too.
I'm assuming... that this is not normal and I need to replace the item - whatever its called.
Any idea?
Old Jul 4, 2015 | 06:07 PM
Tommy79's Avatar
Tommy79
I've found where I can replace the complete control unit, but not just the problem part.
Old Jul 4, 2015 | 06:11 PM
Street Rat's Avatar
Street Rat
You can purchase just the vacuum switch separately. Less than $20 but not fun to replace.
Old Jul 4, 2015 | 06:37 PM
Tommy79's Avatar
Tommy79
Default Thanks...
But probably less fun than paying $120.00 for the complete assembly.
To Temp control vacuum leak
