Engine popping
Old Jul 7, 2015 | 09:42 PM
Almora's Avatar
Almora
5th Gear
Default Engine popping
So I took my 78 standard on the first longer road trip this weekend. It seemed to be running good. When I stepped it down at freeway speed the engine made a couple loud pops from under the hood like a backfire. It did this two or three times. Any ideas?
Old Jul 7, 2015 | 09:43 PM
diehrd's Avatar
diehrd
A lean mixture pops out exhaust
Old Jul 8, 2015 | 01:42 PM
gungatim's Avatar
gungatim
lean or possibly pinging? is your timing correct? maybe someone put popcorn kernels on the exhaust manifold : )
Old Jul 8, 2015 | 10:20 PM
Almora's Avatar
Almora
5th Gear
I do love me some popcorn! It's more of a backfire. I'll check the timing. The car sat for 10 yrs and I suspect that may be causing a few issues. I threw in plugs and wires. Maybe a carb rebuild?
Old Jul 9, 2015 | 11:38 AM
TimAT's Avatar
TimAT
Bad plug wire, bad distributor cap/rotor, swapped plug wires, valve train problems. You already did plugs and wires, just go on down the list.
Old Jul 9, 2015 | 09:47 PM
Peterbuilt's Avatar
Peterbuilt
Default An easy fix!
I agree, try turning both idle mixture screws OUT 1/4 to 1/2 turn.
Old Jul 9, 2015 | 09:54 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Replace the cap and rotor, if that turns out not to be the problem it's still cheap insurance. If that is the problem and you keep driving you'll be on the hook soon enough!
To Engine popping
