The heads of the bolts are accessible inside the car. The seats slide back and forth on runners (slides). There's a bolt at each end of the runner. If you look at the end of the runners, you'll see a maybe two parallel 2 1/2 inch cuts in the carpet. The cuts will allow you to lift up a small strip of carpet. When you lift up the carpet strip, you'll see the bolt head.
OK. Thanks.
Is there a nut welded onto the underside of the floor pan that the bolt threads into?
This should only take 5 minutes per seat to remove provided the bolts aren't badly rusted. Use a 6 point socket the first time to avoid rounding off the bolts. Also having the t-tops out makes it easier to extract the unbolted seats from the car. Good luck.
