I finally got around to the tach issue again. I was fiberglassing the battery compartment (fixing the hole and adding a battery tie-down) and also replacing the Power Steering Assist.
Anyway, I found the tach filter. It has an MSD box along with the MSD distributor. The MSD box had about 16" of redundant wiring attached to the tach filter. When I picked up the tach filter and one of the wires just fell off! So definitely a loose connection. Another thread said you can bypass it so that's what I am trying first and see if I even need to replace it. I will update the thread as I found more info.
I'm running MSD box and MSD distributor with factory tachometer and no filter. And it's working fine for me.
Great! I wanted to fire her up last night but didn't want to wake everyone in the house up. Maybe when I get home from work tonight. (There is a fair in town this week!)
Well I started her up the other day after removing the tach filter and it works fine. The tach filter was not bolted down and was just laying there in a bunch of wires.
