1978 Seat Removal
Old Jul 18, 2015 | 02:06 PM
DFW78's Avatar
DFW78
Cruising
Default 1978 Seat Removal
How do you remove the seats. Also can the driver seat be replaced with the passenger seat.
Old Jul 18, 2015 | 02:59 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
There are four bolts which attach the seat track to the floor. Move the seat all the way back and pull away some of the carpet and you should see a bolt on each corner. Then just unscrew them. Then move the seat all the way forward and do the same. The seat should should then lift out. Be careful not to to hit the door jamb with the seat tracks. Sounds like you need a GM shop manual for your car. The driver and pax seats s/b reversible (at least they are with a '76.)
Old Jul 19, 2015 | 09:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...can the driver seat be replaced with the passenger seat...
Yes.
To 1978 Seat Removal
