Ignition Module
Old Jul 31, 2015 | 10:30 PM
blk79nj's Avatar
blk79nj
Default Ignition Module
Great night for a cruise.
So I'm going along, t-tops out nice breeze coming in, jamming on the radio. About a mile from home, the car shuts off at 40mph.
I coast to the side of road. Good thing I had just got off the highway. The car was on the shoulder near a traffic light, so no fear of getting run over.
So I started to trouble shoot what the problem is. I move the carb linkage, the accelerator pump is shooting fuel, so it's not that.
I call my son and had him bring me my old distributor that was in the garage, along with my Craftsman tool case. My car is a 79, so it has an HEI distributor. I change out the ignition module, and if fires back up. I was actually waiting longer for him to get there then it took to change it out.
Now, the reason I have an old one, is because I though I was being proactive, and just replaced everything in the spring. Cap, roter, module, wires, and plugs.
This leads me to this question. Are the new ones junk? Should I buy a gross of them, and keep them in the rear compartment?
Old Aug 1, 2015 | 12:56 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
From the threads I have read.......make sure there is plenty of the WHITE electrical grease under the module (substitute grease causes early module failure)
Also.....use an ohm meter to make sure that the pickup coil wiring is not broken inside the insulation (when you install a new module, you could be repositioning the broken pickup coil wiring so that it makes contact for a while......causing the HEI to work correctly until the broken wire loses contact again)
Old Aug 1, 2015 | 05:30 AM
toobroketoretire's Avatar
toobroketoretire
Some of you may scream when you read this but many years ago I started using Permatex Ultra Black RTV under the module and it seems to be doing the job just fine. The object is to transfer heat from the module's internal parts and the RTV does that.
Old Aug 1, 2015 | 08:21 AM
LT-1 kid's Avatar
LT-1 kid
most of these new modules and componets is china made junk.
Old Aug 1, 2015 | 08:29 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Use OEM parts (DELCO).
Old Aug 1, 2015 | 09:46 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
RTV does not transfer the Heat.
use heat sink conductive paste on the module.
To Ignition Module
